Iceman Posted August 4, 2010 Report Share Posted August 4, 2010 I just got some used wheels for my Z and the offset puts them out more than I had hoped. I figure they are about a -10mm if I understand how to do the measurements properly. They are 8" wide with a measurement of 3 1/8" from the rear lip to the back of the hub. With them mounted, they sit with about 1" of the width threatening to hit the edge of the fender. What kind of measurements can I take to see if ZG flares will make enough of a difference to use these wheels? Is there a certain amount of clearance from the top of the tire to the fender lip that I wont even need to worry about it? Quote Link to comment
Skib Posted August 4, 2010 Report Share Posted August 4, 2010 I plan on tucking 10in wheels under ZGs. are they close enough that you can just roll the fender? put em on and take some pics Quote Link to comment
INDY510 Posted August 4, 2010 Report Share Posted August 4, 2010 Where did you find a 8inch wide wheel with a -10mm offset?...... ... .. .. what diameter? I'm shure most people have seen that dark blue 240z with cf zg flares and the HUGE 16" Watanabes They rears are 16x9.5 -19 and are tucking into the ZG flares quite nicely....... I'm not shure what mods the car has though The fronts are 16x8.5 -6 It all depends on how slammed you want it,,,, and how much you like camber Because Yuta's slammed Z is tucking 15x10s in the front with 205 tires and a super crazy negative offset Quote Link to comment
hughdogz Posted August 4, 2010 Report Share Posted August 4, 2010 I'm with Skib...ZG's might be too much. I think they add 2" or so, plus you have to trim down the fender arches & re-weld to install them. Even if they stick out a bit at static ride height, they may be able to tuck in a little under compression. Quote Link to comment
