Datsun Parts Posted August 2, 2010 Report Share Posted August 2, 2010 I have a 81 Turbo and and runs perfect! Problem is it stalls after a few seconds when you stop (for a light or in traffic), in neutral or park it idles great, but as soon as you put it in drive it slowly dies like its starving for fuel? I have checked for vac. leaks, recently tuned the car with new injectors, FPR, cap , rotor, wires, plugs and so on. Even rebuilt the turbo. I was told it could be a idle control valve and that the idle is not adjustable? Anyone else have ideas? Here is a few photos of her. Thanks in advance, Al Quote Link to comment
metalmonkey47 Posted August 2, 2010 Report Share Posted August 2, 2010 Have you checked the brake booster for leaking diaphragm causing a vac leak? BTW, Nice Z :) Looks immaculate! Quote Link to comment
Skib Posted August 2, 2010 Report Share Posted August 2, 2010 I was told it could be a idle control valve and that the idle is not adjustable? Anyone else have ideas?G] the idle control valve as their calling it is the air idle control valve or the air regulator, it ups the RPM's when you start it cold like a choke. try just unplugging it and see if it still does that. theres also the FSM available for DL at Xenon Z car BTW, Nice Z :) Looks immaculate! x2 :cool: Quote Link to comment
hughdogz Posted August 4, 2010 Report Share Posted August 4, 2010 The IAC is "dumb" and slowly closes a gate valve to bring down the idle RPM's after a certain time. If this was the problem, you'd see different behavior when the engine is cold or warmed-up. The Airflow meter probably needs adjustment since the idle is kicked up on an A/T when you're in gear. I would think you'd need to richen it a bit so it won't starve for fuel and die. Something to try if upping the idle with the linkage stop screw on the throttle body doesn't work. Quote Link to comment
