Dirttrack510 Posted July 28, 2010 Report Share Posted July 28, 2010 I am trying to build a long rod 2.1 liter frankenstein engine. what is the difference between the Z20E rods and the L20B rods? The company I was going to order the rods from shows the same part number for both rods. I was under the impression that the Z20E rod was a little longer than the L20B rod. Any help would be greatly appreciated. Quote Link to comment
Master-O-Turbonics Posted July 28, 2010 Report Share Posted July 28, 2010 http://community.ratsun.net/topic/22872-discrepancy-in-z20e-connecting-rods/ Quote Link to comment
hang_510 Posted July 29, 2010 Report Share Posted July 29, 2010 ^ that and... the Z20E rod was a little longer than the L20B rod. Any help would be greatly appreciated. 6.6mm longer Quote Link to comment
Dirttrack510 Posted July 29, 2010 Author Report Share Posted July 29, 2010 ^ that and... 6.6mm longer Thanks for the quick replys. I just found this little connecting rod chart myself too. Connecting rods Center to center length, all use the same 21mm diameter piston wristpin. L18, L28, L26--------------130.2mm L16, L24---------------------133.0mm L13----------------------------139.9mm L20B, Z22S, early Z22E-145.9mm* Z20S,- ------------------------??** Late Z22E-------------------149.5m* Z20E--------------------------152.5mm Z24, KA24-------------------165.0mm Quote Link to comment
Master-O-Turbonics Posted July 29, 2010 Report Share Posted July 29, 2010 Thanks for the quick replys. I just found this little connecting rod chart myself too. Connecting rods Center to center length, all use the same 21mm diameter piston wristpin. L18, L28, L26--------------130.2mm L16, L24---------------------133.0mm L13----------------------------139.9mm L20B, Z22S, early Z22E-145.9mm* Z20S,- ------------------------??** Late Z22E-------------------149.5m* Z20E--------------------------152.5mm Z24, KA24-------------------165.0mm and LD28 rods are 140mm and HEAVY DUTY. LOL Quote Link to comment
