djaztek12 Posted July 21, 2010 Report Share Posted July 21, 2010 hey guys i got a problem took my car to the dyno, and she lean out real bad after 7k. she made power between 2 to 7k and after 7k she lean out bad all the power drop. the a/f was around 15 to 15 1/2 we thought that was a bit high when i ask around they said it should be @ 12 to 12 1/2. with this set up she did 165 whp. on a dyno pac dyno. heres the set up. 13b 6 port n/a standar Bridge Port 2 msd 6a boxes 2 msd coil blaster 2 coils 48 weber ida 43 mm venturis f11 tubes 210 mains 150 air 70 idle 300 needle. i though that was bad for fo a bp motor total power 185 rwd not bad :P Quote Link to comment
INDY510 Posted July 21, 2010 Report Share Posted July 21, 2010 Those pics aren't working Quote Link to comment
datzenmike Posted July 21, 2010 Report Share Posted July 21, 2010 :lol: :lol: :lol: :lol: Haven't followed this. What motor? Quote Link to comment
djaztek12 Posted July 22, 2010 Author Report Share Posted July 22, 2010 Those pics aren't working i haven't aded pictures :P Quote Link to comment
S@nt0s Posted July 22, 2010 Report Share Posted July 22, 2010 first mistake its a rotary... LOL had to do it sorry but i break out in a rash when near one.. a/f in the 12s is way rich for a NA set up. stick to around the 13.5 range also 185 ona dynapak is about 160 on a dynoyet and less on a dynamic. but with that power with hooking up you might get lucky with a high 13 but looking around low to mid 14's in the 1/4 to give you a idea at the track Quote Link to comment
djaztek12 Posted July 22, 2010 Author Report Share Posted July 22, 2010 first mistake its a rotary... LOL had to do it sorry but i break out in a rash when near one.. a/f in the 12s is way rich for a NA set up. stick to around the 13.5 range also 185 ona dynapak is about 160 on a dynoyet and less on a dynamic. but with that power with hooking up you might get lucky with a high 13 but looking around low to mid 14's in the 1/4 to give you a idea at the track isn't a dyno pac dyno better cause it connects straight to the hub then a dynoyet, mustan or a dynamic Quote Link to comment
510six Posted July 22, 2010 Report Share Posted July 22, 2010 isn't a dyno pac dyno better cause it connects straight to the hub then a dynoyet, mustan or a dynamic The dyno pack dyno is the most accurate dyno as there is NO wheel slip,IMO a 12.5 to 12.2 A/F ratio is a "safe" ratio for a N/A motor. http://dynapack.com/ Quote Link to comment
djaztek12 Posted July 22, 2010 Author Report Share Posted July 22, 2010 The dyno pack dyno is the most accurate dyno as there is NO wheel slip,IMO a 12.5 to 12.2 A/F ratio is a "safe" ratio for a N/A motor. http://dynapack.com/ i thought so thanks :P Quote Link to comment
ohpyramids Posted July 22, 2010 Report Share Posted July 22, 2010 i have it on good authority that webbers want 41 venturis with a bridgeport. i had them on my streetported 13b, but it runs much better with 39 venturis. would probably find all the info you could dream of at the rotary forums. very few dudes on here have a rotary swap, and even less that have the swap know what they are doing. you could be losing a bunch of power from your exhaust. going to a 2.5" freeflow racing beat type pipe can gain you +30 hp over stock. thats the first place id look. then jump to the intake and flywheel, and try some electric fans too. a bridgeport should put you into the 200-240 hp range if tuned properly. your porting is definitely affected by which exhaust tins you have, and if the sleeves were removed. sorry if this stuff is basic, i havent look at your threads, i dont know your experience level. Quote Link to comment
djaztek12 Posted July 22, 2010 Author Report Share Posted July 22, 2010 i have it on good authority that webbers want 41 venturis with a bridgeport. i had them on my streetported 13b, but it runs much better with 39 venturis. would probably find all the info you could dream of at the rotary forums. very few dudes on here have a rotary swap, and even less that have the swap know what they are doing. you could be losing a bunch of power from your exhaust. going to a 2.5" freeflow racing beat type pipe can gain you +30 hp over stock. thats the first place id look. then jump to the intake and flywheel, and try some electric fans too. a bridgeport should put you into the 200-240 hp range if tuned properly. your porting is definitely affected by which exhaust tins you have, and if the sleeves were removed. sorry if this stuff is basic, i havent look at your threads, i dont know your experience level. exhaust is racing beat set up electric fan. just to wacky a friend he said to change the air jets to 120, and maybe the main to a 230 and thats all she needs :lol: Quote Link to comment
S@nt0s Posted July 23, 2010 Report Share Posted July 23, 2010 The dyno pack dyno is the most accurate dyno as there is NO wheel slip,IMO a 12.5 to 12.2 A/F ratio is a "safe" ratio for a N/A motor. http://dynapack.com/ more then safe its rich, it will yeild more power and still be ok leaning it out some. now it the comp was high and running pump gas i would keep it rich to help prevent detonation and maintaining the champers cool Quote Link to comment
