Chingon 510 Posted July 14, 2010 Author Report Share Posted July 14, 2010 my trans still dont go in can it be my clutch is not aligned? Link to comment
datzenmike Posted July 15, 2010 Report Share Posted July 15, 2010 If you have not removed it, it should still be aligned. The 'nose' on the front of the input shaft should slip right in. Use a flash light and look in the middle of the pressure plate fingers. The pilot bearing is in the end of the crank shaft. mine is a bit rusty... . Link to comment
I'm BLUE Posted July 15, 2010 Report Share Posted July 15, 2010 Are you still looking for a trans Chingon510 ? Did you use a clutch alignment tool ( needs to be or an old input shaft before putting trans in if the clutch disc was moved or assembly loosened at all in between Looks like this about $5-6 most at a auto parts store ( or may have to order off line like RockAuto.com ) Link to comment
Chingon 510 Posted July 17, 2010 Author Report Share Posted July 17, 2010 i think i will just have pull my engine to bolt them up together then go in as one? what do you guys think? Link to comment
datzenmike Posted July 17, 2010 Report Share Posted July 17, 2010 It would seen so. A picture might show something you missed. :confused: Link to comment
Chingon 510 Posted July 17, 2010 Author Report Share Posted July 17, 2010 im taking pic of what tho? what do you wanna see? Link to comment
datzenmike Posted July 17, 2010 Report Share Posted July 17, 2010 Motor tilted back, front of tranny anything you can think of. Grasping at straws here as I've never heard of someone intsalling this 5 speed who didn't get it in. Maybe it's something very simple. Link to comment
