foxarelly Posted June 8, 2010 Report Share Posted June 8, 2010 Ok the rear end in my 521 leaks and the guy who owned it before me welded up the rear end!!! i want to swap it out but dont know what would be a suitable replacement! Any ideas??? I also plan on doin a 5 speed swap!! Quote Link to comment
datzenmike Posted June 9, 2010 Report Share Posted June 9, 2010 Ok the rear end in my 521 leaks and the guy who owned it before me welded up the rear end!!! i want to swap it out but dont know what would be a suitable replacement! Any ideas??? I also plan on doin a 5 speed swap!! Exactly what did he weld? The third member to the axle housing???? Quote Link to comment
foxarelly Posted June 9, 2010 Author Report Share Posted June 9, 2010 Exactly what did he weld? The third member to the axle housing???? he welded the spider gears so its posi ALL THE TIME!!! Quote Link to comment
datzenmike Posted June 10, 2010 Report Share Posted June 10, 2010 Of course. The redneck LSD. Any 521 or 620 (except the '74 auto and '79 standard) are the same ratio. 720 4X4s to '82? Somewhere around '82 the drive shaft yoke became bigger and won't work on yours. If you want a lower ratio check the 720 2wds. '82 automatics had 4.11 standards were 3.889 there were also 3.70s. Quote Link to comment
foxarelly Posted June 10, 2010 Author Report Share Posted June 10, 2010 Of course. The redneck LSD. Any 521 or 620 (except the '74 auto and '79 standard) are the same ratio. 720 4X4s to '82? Somewhere around '82 the drive shaft yoke became bigger and won't work on yours. If you want a lower ratio check the 720 2wds. '82 automatics had 4.11 standards were 3.889 there were also 3.70s. thank you!! Quote Link to comment
datzenmike Posted June 10, 2010 Report Share Posted June 10, 2010 The '74 auto was 4.625 and the '79 standard was 4.11 otherwise they were 4.375. Quote Link to comment
