the inline4 quick dumb question thread
  • Replies 6
I replaced my headlight relay because my lights would go nuts. I tried getting a oem headlight relay and it didnt work so I got an Single Pole Double Throw (SPDT) relay from ebay like the the one listed on this thread. Follow the drawn diagram and you are good. They carry same relay and plug at Fry's, probably even Radio Shack. They have worked fine since. Good Luck.
http://www.the510realm.com/viewtopic.php?f=2&t=8226&p=84096&hilit=headlight+relay+bosch#p84096
I have the relays, I was trying to wire these in the garage last night with a work light shining on me. I just need to track down the wires to use. the two on the headlight relay.
I'm assuming the headlight relay is the 6 pin rectangular relay behind the passenger strut tower. if thats the case I could only spot the black and red wire. the colors might have been washed out by the work light.
I guess im looking for the pinout, so I dont screw things up.
edit: I just found a diagram. I think I'm good :)
