flashg Posted June 8, 2010 Report Share Posted June 8, 2010 Just got my first 620 and the first real issue is to repair the hood hinges. both are rusted and broke. Help! Thanks Quote Link to comment
Pacific coast Datsun Posted June 8, 2010 Report Share Posted June 8, 2010 Rust- sand / grind off, primer then repaint. Broke- replace. remove cowl & you'll see the 10mm bolts that hold them on. im sure somebody on the forum will give em to you free, at least i hope so. Quote Link to comment
datsunaholic Posted June 8, 2010 Report Share Posted June 8, 2010 The hinges aren't held on by 10mm bolts, they're spot welded to the cab body. Sometimes you can weld them back down, but sometimes they're just too broken. They break off when the hinge itself siezes up. There's a lot to rust under the cowl, so those really need to be checked periodically. Quote Link to comment
Pacific coast Datsun Posted June 8, 2010 Report Share Posted June 8, 2010 The hinges aren't held on by 10mm bolts, they're spot welded to the cab body. Sometimes you can weld them back down, but sometimes they're just too broken. They break off when the hinge itself siezes up. There's a lot to rust under the cowl, so those really need to be checked periodically. Doug your right im sorry. I was thinking of the HB's. Quote Link to comment
Craig Posted June 8, 2010 Report Share Posted June 8, 2010 If your in so Cal your welcome to have mine. I have. A 73 620, just come by and help me grind them off. Quote Link to comment
