Chingon 510 Posted June 5, 2010 Report Share Posted June 5, 2010 whats up guys i need a 5 spd trans asap. that will fit a 71 2dr 510. i heard the best to go with is from a 85,86 720spd? help plz Link to comment
datzenmike Posted June 7, 2010 Report Share Posted June 7, 2010 whats up guys i need a 5 spd trans asap. that will fit a 71 2dr 510. i heard the best to go with is from a 85,86 720spd? help plz Negative. For a 5 speed that is the same length, (so you don't have to shorten the drive shaft) will bolt up to your L16 motor and have the speedometer cable on the same side is the FS5W63A dogleg from a '77-'79 200sx or the optional 5 speed from the '79 A10. The rear mount will need to be modified to fit. Link to comment
Chingon 510 Posted June 7, 2010 Author Report Share Posted June 7, 2010 my trans now is about 27 inch in length from bellhousing to tail of trans so what should i use i need one asap,and yeah i dont have a speedometer Link to comment
zerow Posted June 7, 2010 Report Share Posted June 7, 2010 my trans now is about 27 inch in length from bellhousing to tail of trans so what should i use i need one asap,and yeah i dont have a speedometer Rumor had it (I have not personally seen the car...)but there is an A10 with the 5 speed in the all import yard in Fontana. Could be worth the look. I do not know if the trans is still there, so it is more of a check at your own risk, but there are lots of other Datsuns there ready for the plucking. Good Luck. Link to comment
Chingon 510 Posted June 7, 2010 Author Report Share Posted June 7, 2010 ok so my dogleg blew out this weekend. im looking for a new trans, i want a 5spd. and my old trans was about 27' in lenght help. plz i need a trans asap Link to comment
izzo Posted June 7, 2010 Report Share Posted June 7, 2010 Double post = fail, you already have a post in the parts wanted section... Please dont do that it just clutters the board up, goto your previous thread and just post a reply. It will make it be on top of the list again. Good luck Link to comment
D@tsuks Posted June 7, 2010 Report Share Posted June 7, 2010 You can bolt your bellhousing off of your dogleg to this dogleg from a 78 b210 gx for $250.00 Link to comment
Chingon 510 Posted June 8, 2010 Author Report Share Posted June 8, 2010 thanks for the tip zerow.... Link to comment
Chingon 510 Posted June 8, 2010 Author Report Share Posted June 8, 2010 whats the length on that trans Link to comment
zerow Posted June 8, 2010 Report Share Posted June 8, 2010 whats the length on that trans Per datzenmike, the length should be the same as the dogleg. Like I mentioned, I knew of the car being there, with a 5 speed. I can't use the 5 speed, so it ended up as a surplus item, and I continued on. Link to comment
