dash removal 521
52tha1
  • Replies 5
2 bolts on each side. 4 bolts under the windshield. leave the wires and switches and cluster in. lower the steering wheel and unplug the 2 wire harness plugs under the glove box. undo speedo cable. done. maybe unplug radio antenna and pay attention to all after market add ons and where the wires may go through the fire wall. unhook manual choke if there.
If you haven't already found out, you can get a 520 dash which is all metal and put it in the 521. But you need the defrost vents from the 520 too as they are specific.
