Dropmaster Posted May 28, 2010 Report Share Posted May 28, 2010 I have a 1978 620 truck. The fuse box on the dase, I keep blowing the bottom left fuse. Does anyone know what that fuse goes to? Quote Link to comment
skunk Posted May 28, 2010 Report Share Posted May 28, 2010 it should be a 10 fuse, looks like my book says Meter Reverse Regulator Quote Link to comment
Dropmaster Posted May 29, 2010 Author Report Share Posted May 29, 2010 Sorry, I didn't add enough info. I put a new fuse in and it blew right away. I have a short some where. I was wondering if someone new what the bottom left fuse went to, so I would know where to look for the short. Quote Link to comment
datzenmike Posted May 29, 2010 Report Share Posted May 29, 2010 Meter Reverse Regulator Answered. It powers the brake light, charge light, temp light and the oil light in the dash (meter) Powers the reverse light switch in the tranny. Powers the turn signal switch for flashers. Did this just happen or did you just get this car and do not know the history? If it just happened then think back to what you have done lately that might have caused it. If you changed the starter or transmission then the reverse light wires may have been pinched. Have you had the tail lights off or been working on them? Are there any loose wires back there?Try disconnecting the reverse light switch wires on the tranny. I assume its a standard? The reverse light switch is on the pass side a few inches behind the clutch arm with two black wires. Quote Link to comment
Dropmaster Posted May 29, 2010 Author Report Share Posted May 29, 2010 Awesome! I just got the truck. I don't know the history behind it. However, the first thing I did to the truck was to put a starter on it myself. Nothing on the dash works. The charge light is on. Quote Link to comment
