Fuse Box ??
  • Replies 4
Meter
Reverse
Regulator
Answered.
It powers the brake light, charge light, temp light and the oil light in the dash (meter)
Powers the reverse light switch in the tranny.
Powers the turn signal switch for flashers.
Did this just happen or did you just get this car and do not know the history? If it just happened then think back to what you have done lately that might have caused it. If you changed the starter or transmission then the reverse light wires may have been pinched. Have you had the tail lights off or been working on them? Are there any loose wires back there?Try disconnecting the reverse light switch wires on the tranny. I assume its a standard? The reverse light switch is on the pass side a few inches behind the clutch arm with two black wires.
