RGB Posted May 27, 2010 Report Share Posted May 27, 2010 After reading just about every post about carbs on the board I was thinking about buying Weber 32/36 this weekend. I have an 85 KC 4X4 with 160K on it. The truck starts and runs well and gets 17 mpg, but has a slight stumble when I shift. I did a tune up and was able to tune out most of the stumble, but not all. I can't tell if the secondaries are opening or not. Should I be able to hear, or feel it when they open like on a four barrel? Other issues are that the throttle control solenoid does not work and the float level is a little high. The muffler rusted through and fell off, so I'm having a complete new system put on next week with 2" pipe and a Flowmaster 60 series. I guess I'm just wondering if I'll notice much of a difference. By the way this truck is just a dump runner and hunting rig, so if mpg goes down it's no big deal. Quote Link to comment
banzai510(hainz) Posted May 27, 2010 Report Share Posted May 27, 2010 Nice looking truck. 2ndaries on a stock carb are vaccum operated(diaphram). so when you go over a certain speed more vaccum the plate will open letting gas in that circut.I guess ck the plate and push on it see if its smooth opertaion. What I used to do soemtimes is get the motor reving hight enought and cover the main bareel with your hand and open the secondary and see if motor stays running. Weber DGV has a mechanical 2nd. which somtimes has a bog also as it opens up the 2nd dary.The stock carb is smoother. As with the newer Napz motors their is more emmision stuff and hardware. alsway ck on these but IM not a NAPZ guy. all I can say it do the basics and time it again. Maybe adjust the mixture also. You say a slight stumble when you shift? You might not even get up high enough motor speed wise to get in the 2ndary side of the carb. For the exhaust Flowmasters are loud and they rust from the inside out. Its almost better to get a cheap Turbo muffler from Thrush,Maremount CheeryBomb Turbo 2 or a Dynomax super turbo. 2inch would be fine.NO more than 30$ for the muffler. Even my Dynomax is getting louder and want to get a more quiet muffler Datzenmike should be able to help more on this subject. Quote Link to comment
RGB Posted May 27, 2010 Author Report Share Posted May 27, 2010 Thanks for the advice. I've been very happy with Flowmasters on three previous vehicles. I didn't think it was loud enough on my V8 Jeep, but this is my first four cylinder truck so we'll see how it sounds. Right now It's just the cat and about 2' of pipe and it's not to bad. Quote Link to comment
banzai510(hainz) Posted May 27, 2010 Report Share Posted May 27, 2010 Sounds like you have your mind made up already on the Flowmasters.I think most are big and heavy. Datdoug on here had one and he didnt like it.Too loud Usaully get a cetain resonance right above hiway speed.Get annoying after awhile. Im sure around town its fine. A Toyata Tundra guy here says they rust out at the vaines they put in on the bottom. Can see the outline of the vaines as they rust thru. Your cat will help keeping the noise down better. Quote Link to comment
RGB Posted May 27, 2010 Author Report Share Posted May 27, 2010 I'm pretty much set on the muffler. I was just trying to decide if the Weber is worth the $350. Quote Link to comment
banzai510(hainz) Posted May 28, 2010 Report Share Posted May 28, 2010 Weber is a bit much@350$ if its the whole kit. I try to get them in the 150 dollar range. if Quesionable they are only worth 40$ to me if that. adjust the mixture and timming and see how it goes? Quote Link to comment
metalmonkey47 Posted May 29, 2010 Report Share Posted May 29, 2010 I'm pretty much set on the muffler. I was just trying to decide if the Weber is worth the $350. Check out ebay. They're MUCH cheaper used with a rebuild kit. I payed $100 for mine and it's working alright Quote Link to comment
RGB Posted June 19, 2010 Author Report Share Posted June 19, 2010 It WAS worth it. I started by having the entire exhaust system replaced with a new cat, turbo muffler and all 2" pipe. That alone made a respectable difference. The old cat was so plugged we couldn't see any light when a flashlight was shined through it. I bought a new 32/36 Weber kit yesterday and installed it last night. This morning I finished up the last few things and took it for a test drive. It's a whole new truck. The Weber really woke up that old engine. I went and filled the tank so I can see if the mileage changes. With just the new exhaust it was still right at 17 mpg. Question. What should I set the timing at now that all of the emissions have been removed? Quote Link to comment
sinner720st Posted June 20, 2010 Report Share Posted June 20, 2010 i have a naps z24 i run the timing at 10-12 degrees advanced, some say thats a little high but i have never had any detonation problems, i would say set it around ten, also try some different settings you might notice a sweet spot... britains set their timing as advanced as possible without encountering detonation Quote Link to comment
nismo dr Posted June 20, 2010 Report Share Posted June 20, 2010 we ran a bunch of mufflers thru a flowbench when I was in school. Flowmaster faied very poorly, the noise doesn;t = flow. Magnaflow and borla were by far the best, I'll try to fing my notes that have the actuall numbers. the pos $14 turbo muffler from O'reiley flowd better than the flowmaster Quote Link to comment
banzai510(hainz) Posted June 20, 2010 Report Share Posted June 20, 2010 you could put a smaller jet in the 2nd barrel to get maybe better milage. Glad it worked out for you. Did you use the Flowmaster ot the muffler shop suggest another type of Turbo muffler.? Quote Link to comment
RGB Posted June 21, 2010 Author Report Share Posted June 21, 2010 They didn't have the Flowmaster I wanted, so I just went with what he called a performance turbo muffler. I don't know what brand it is, but it sounds nice. I'm not really concerned with the mileage just curious. Thanks for the advice. With the huge improvement of the 32/36 I wonder what a 38 outlaw would do. Quote Link to comment
