mikec Posted May 27, 2010 Author Report Share Posted May 27, 2010 i'll try to find where the hose came from, but i had no luck looking last night... also, here's a pick of how i set up the spacers - just want to make sure i did it right before alignment. only one side had stock washers, so it worries me because either nissan missed something or i did...and ten times out of ten it's usually me haha Quote Link to comment
PEZi720 Posted May 27, 2010 Report Share Posted May 27, 2010 nah that's perfect.... just makes sure the two bolts have the same amount of spacers and you're good Quote Link to comment
PEZi720 Posted May 27, 2010 Report Share Posted May 27, 2010 doesnt that one go to the air breather too, not sure due to all of mine is deleted... i got no idea... it could be i don't even have the stock carb anymore so i have no idea where any stock lines run besides the dizzy advance Quote Link to comment
izzo Posted May 27, 2010 Report Share Posted May 27, 2010 nah that's perfect.... just makes sure the two bolts have the same amount of spacers and you're good +1 lol Man i thought the later 720s were different.. I guess its just the hardbody pickups. i guess thats why they made drop spindles for them Quote Link to comment
mikec Posted May 28, 2010 Author Report Share Posted May 28, 2010 alright, found the missing hose and got it all sorted out. is there really no way for a weber to pass ca smog? the place I have my car smogged is run by a quiet little vietnamese man that seems to me like he'd turn the other shoulder.. Quote Link to comment
PEZi720 Posted May 28, 2010 Report Share Posted May 28, 2010 webers are not street legal (anywhere really... but that's more of a gray area) in cali for sure... even if the guy you know passes you on the visual... it might not pass smog anyway on the running test Quote Link to comment
84nissan720 Posted May 28, 2010 Report Share Posted May 28, 2010 alright, found the missing hose and got it all sorted out. is there really no way for a weber to pass ca smog? the place I have my car smogged is run by a quiet little vietnamese man that seems to me like he'd turn the other shoulder.. i got same guy that pass allmost ever thing that has wheels on it were in socal do u live? Quote Link to comment
mikec Posted May 28, 2010 Author Report Share Posted May 28, 2010 i'm in the south bay, but i'm willing to make a trip if he'll let it slide. my truck barely passes as it sits right now! i'm due for my next check next may. i bet you all wish your floors were this clean!! Quote Link to comment
nis720 Posted May 28, 2010 Report Share Posted May 28, 2010 also, one of the hoses keeps coming disconnected from my carb...i think it's a vacuum hose, and now it's missing. what does it do? It's been a while since I messed with a Z24 engine. But I found a pic of my old engine that might help. Quote Link to comment
PEZi720 Posted May 28, 2010 Report Share Posted May 28, 2010 i'm in the south bay, but i'm willing to make a trip if he'll let it slide. my truck barely passes as it sits right now! i'm due for my next check next may. i bet you all wish your floors were this clean!! mine might be.... lol but its hard to tell... i don't have any legit 'floor pics' Quote Link to comment
mikec Posted May 28, 2010 Author Report Share Posted May 28, 2010 ^ haha dang! I'll stfu now. Quote Link to comment
PEZi720 Posted May 28, 2010 Report Share Posted May 28, 2010 ^ haha dang! I'll stfu now. lol... nah man you just started on yours... i've had mine since i was 15 Quote Link to comment
datzenmike Posted May 28, 2010 Report Share Posted May 28, 2010 This is an Electronic Controlled Carburetor (ECC) and has an ECU with throttle position sensor, O2 sensor, fuel cut off system and more. Note the 6 wire round plug at the back.. No Weber will beat that for emissions. Put it all back on for the test and swap it back later. . Quote Link to comment
Kevin S. Posted May 28, 2010 Report Share Posted May 28, 2010 I had a weber on my 80 720.... When I took it through DEQ in Washington I told the dude he wasn't going to run it,,,, that I would I failed the cruse part of it. It was running rich. I had to create a controlled vacuum leak to lean it out. I just teed a vacuum line into the cab by the shifter were I could cap it off with my thumb and when he told me to bring it up to 2200 rpm I just took my thumb off the line. It passed.. Just food for thought. Quote Link to comment
mikec Posted May 29, 2010 Author Report Share Posted May 29, 2010 ^ interesting...I'll think about that @pezi720 I've had mine since 15 too...my dad bought it new in '85 and gave it to me in HS. I've just never gotten around to anything besides preventative shit. by the way, the alignment shop adjusted my caster by changing the shims I put in...will having a different number on each side of the UCA eventually rub/shear into the frame or control arm or is that okay? Quote Link to comment
PEZi720 Posted May 29, 2010 Report Share Posted May 29, 2010 ^ interesting...I'll think about that @pezi720 I've had mine since 15 too...my dad bought it new in '85 and gave it to me in HS. I've just never gotten around to anything besides preventative shit. by the way, the alignment shop adjusted my caster by changing the shims I put in...will having a different number on each side of the UCA eventually rub/shear into the frame or control arm or is that okay? ugh... that's sorta a gray area.... it should be ok... but next time you see them... SLAP THEM! Quote Link to comment
mikec Posted May 29, 2010 Author Report Share Posted May 29, 2010 yeah when I asked the tech to go over exactly what he did and he was like "the caster was way off so I had to change out the shims in the control arms" and I was like "well duh, it's going downhill and I'm lowering the rear to match it as soon as I get some blocks...I told you that..." so whatever. apparently 'lifetime' align means minimum 6 mo wait inbetween aligns... Quote Link to comment
PEZi720 Posted May 30, 2010 Report Share Posted May 30, 2010 apparently 'lifetime' align means minimum 6 mo wait inbetween aligns... really? where at? i went several times on my lifetime alignments and no one ever said anything Quote Link to comment
mikec Posted May 31, 2010 Author Report Share Posted May 31, 2010 ^ at my local firestone...they're convenient b/c they're like .5 miles away, but they're penny-pinchers too so that's annoying. picked up some rims on friday from a fellow ratsun-er...$50 for the set. here's how she looks post-drop/align/rims/etc. Quote Link to comment
mikec Posted June 1, 2010 Author Report Share Posted June 1, 2010 next step is a y-pipe and louder mufflers. i've seen a 720 with them coming straight out the back, but part of me wants the traditional out the sides. what do you guys think??? Quote Link to comment
84nissan720 Posted June 1, 2010 Report Share Posted June 1, 2010 y-pipe straight out the back well thatz just me Quote Link to comment
mikec Posted June 1, 2010 Author Report Share Posted June 1, 2010 here's my goal...first step is finding me that bumper! i know it probably means carrying my spare in the bed too...whatever let me know what you all think Quote Link to comment
Radim Posted June 3, 2010 Report Share Posted June 3, 2010 Truck looks good! I say out the back, looks really sweet you can almost pull it off as stock. Quote Link to comment
bagged320 Posted June 3, 2010 Report Share Posted June 3, 2010 Nice truck man, looks clean, you know if you still want to do somemore mods you can do air suspension, it would look clean stock outside with air bag suspension, just a thought lol Quote Link to comment
mikec Posted June 3, 2010 Author Report Share Posted June 3, 2010 thanks guys, i'm really egging to get that exhaust fabbed, but i've gotta get the right rear bumper first!! also, does someone want to refresh me on what the symptoms of a bad head gasket are? because right now there is a slight 'ffft' sound and a little bit of white smoke out the tailpipe. both are only just noticeable, but i've got 210k and apparently these are supposed to blow at around that? oil looks clean and normal... Quote Link to comment
