need a brake line
Trex72
  • Replies 6
I just made a new one for my car recently. It was pretty easy and only cost about $12. I removed the old one, and used it as a pattern for the bends on the new one. Then just flared the ends and it was good to go.
where did you get the tubing ?
To get a piece long enough, you usually have to go to a place that builds/sells hydraulic hoses/fittings. (that's where I got mine.). It helps if you take part of the original one with you, so they can match it up to the right size and threads for the ends too.
If you don't have the tool or know how to make the flairs, you can buy the tube, take it home and bend it, then bring it back to them and they will put the ends on it for you. Or you can just remove the old one and take it to them and they can even bend it to match the original. It all depends on your tool and skill level.
