hulk210 Posted May 3, 2010 Report Share Posted May 3, 2010 Like the title states, my 1980 210 takes forever to start now. i find myself pumping the gas 8-10 times prior to starting, just to have it die out once in turns over.. repeat process 2-4 times before it wants to get going without dying. i do know the stock carb was rebuilt sometime last year, but this is my first car that was not equipped with fuel injection. not sure if that makes a difference. everything else is stock. A14 motor with 135,xxx miles.. everythings stock. thanks in advance Quote Link to comment
metalmonkey47 Posted May 3, 2010 Report Share Posted May 3, 2010 Have you checked the choke? Quote Link to comment
hulk210 Posted May 3, 2010 Author Report Share Posted May 3, 2010 Have you checked the choke? not yet.. Quote Link to comment
izzo Posted May 3, 2010 Report Share Posted May 3, 2010 id check the choke also, then a good full tune up, plugs, wires, cap, rotor, blah blah... dump some carb cleaner in there too and clean that sob out, gas today is horrible. change filter too. Quote Link to comment
metalmonkey47 Posted May 3, 2010 Report Share Posted May 3, 2010 id check the choke also, then a good full tune up, plugs, wires, cap, rotor, blah blah... dump some carb cleaner in there too and clean that sob out, gas today is horrible. change filter too. X2 I think you just about covered all the possible problems there. lol Quote Link to comment
datzenmike Posted May 3, 2010 Report Share Posted May 3, 2010 When the motor is cold, remove the air filter and look down at the carb. The choke plate will be open or partly open like this: Pump the throttle by hand and the choke plate should snap shut fully like this: . Quote Link to comment
hulk210 Posted May 3, 2010 Author Report Share Posted May 3, 2010 you guys are awesome. changed the oil and air filter a couple of weeks ago, was planning on doing the rest this week. thanks for the pics. complete noob with this car.. thanks again Quote Link to comment
metalmonkey47 Posted May 4, 2010 Report Share Posted May 4, 2010 you guys are awesome. changed the oil and air filter a couple of weeks ago, was planning on doing the rest this week. thanks for the pics. complete noob with this car.. thanks again One thing I've noticed with these stock Hitachi carb's is that the choke pull-off diaphragm has a tendency to wear and eventually will not work properly and leaks vacuum. Quote Link to comment
hulk210 Posted May 4, 2010 Author Report Share Posted May 4, 2010 One thing I've noticed with these stock Hitachi carb's is that the choke pull-off diaphragm has a tendency to wear and eventually will not work properly and leaks vacuum. thanks for the heads up. i will get it checked this week. Quote Link to comment
