AuosGnaf Posted May 1, 2010 Report Share Posted May 1, 2010 I'm trying to replace the wiper switch but the head light knob is preventing me from removing the cluster frame, know what I mean? So how do i remove the head light knob in order to do what I have to do? Keep in mind I didn't remove the wiper knob, it's not connected. Thanks Quote Link to comment
72dyme Posted May 1, 2010 Report Share Posted May 1, 2010 On the knobs, you push in and turn them to the left. That will remove the knobs, then you continue to remove the cluster. Quote Link to comment
datzenmike Posted May 1, 2010 Report Share Posted May 1, 2010 For headlight switch, pull out all the way. Grip the shaft well below the knob close to the dash with needle nose pliers and hold tight. Push the knob down toward the dash and turn to disengage and lift up and off. Quote Link to comment
RadioLobo Posted May 1, 2010 Report Share Posted May 1, 2010 Lol i remember when i had trouble with that :D. It was the only thing from keeping the dash from coming off and I finally figured it out. Quote Link to comment
AuosGnaf Posted May 1, 2010 Author Report Share Posted May 1, 2010 HAHAHA! STUPID! SOO EASY! Thanks guys! Well, I plugged in the new wiper switch and it still isn't working. It could be a dud switch or the wiper motor. How would one find out if it's the wiper motor rather than the switch itself? I know you're 'posed to pull the wiper knob for the wipers to go but nothing. Quote Link to comment
rzrdisco Posted May 7, 2010 Report Share Posted May 7, 2010 Get a multimeter and test each of the leads on the switch. Find the common and such... Quote Link to comment
datzenmike Posted May 7, 2010 Report Share Posted May 7, 2010 Try the washer pump it's on the same fuse. If it isn't working check the second fuse back on the left side. It's 10 amp and has a 20 amp on either side of it. (key has to be ON) Quote Link to comment
