AuosGnaf Posted April 27, 2010 Report Share Posted April 27, 2010 1971 510 WagonHere's the thing... knob for the wipers is NOT connected (bought the wagon it like that) thus, the wipers aren't working. So how do I go about fixing this problem? On a rate from 1 - 10 (10 being the hardest) how hard/difficult is it to fix it? I'm looking for the seat brackets/mounts. I already have the seats with sliding rails, just need the brackets/mounts and all the good stuff that comes with them. Got extras or whatever I'm willing to take them off your hands. Lastly, seat belts! I was only able to screw in the top piece of the shoulder strap, so where would are the other spots to screw/bolt in the lap and lock straps? Any help will do! Thanks. Quote Link to comment
ariascarlos1990 Posted April 27, 2010 Report Share Posted April 27, 2010 Any help will do! How about posting in the Datsun Parts Wanted section? :P Quote Link to comment
hang_510 Posted April 27, 2010 Report Share Posted April 27, 2010 knob for the wipers is NOT connected (bought the wagon it like that) thus, the wipers aren't working. So how do I go about fixing this problem? On a rate from 1 - 10 (10 being the hardest) how hard/difficult is it to fix it? Lastly, seat belts! I was only able to screw in the top piece of the shoulder strap, so where would are the other spots to screw/bolt in the lap and lock straps? Any help will do! KNewBS: Rating = 1 push & twist, done. BTW the switch function w/ or w/o the knob on. BELTS: behind the seat, 1 on the tunnel and the other is on the rocker. Quote Link to comment
AuosGnaf Posted April 29, 2010 Author Report Share Posted April 29, 2010 Thanks guys! Hang 510 - I had to improvise the seat belts, but hey whatever works. And I think the wiper motor is dead, damn thing ain't working no matter how I twist and push the knob. Quote Link to comment
sssr20det510 Posted April 29, 2010 Report Share Posted April 29, 2010 Is the sitch plugged in also check fuses Quote Link to comment
AuosGnaf Posted April 29, 2010 Author Report Share Posted April 29, 2010 sssr20det510 The wiper switch isn't plugged in. I can pull the switch right out of that little hole (if this is what you meant by if it was plugged in). Doesn't feel like anything is grabbing hold. Quote Link to comment
hang_510 Posted April 29, 2010 Report Share Posted April 29, 2010 damn thing ain't working no matter how I twist and push the knob. i thought you meant to remove/install the knob on the switch... twist function is for the washer, IF the bottle/hose/squirters are still there :rofl: do you have a meter to verify continuity on the switch? its likely a bad motor regardless Quote Link to comment
sssr20det510 Posted April 29, 2010 Report Share Posted April 29, 2010 sssr20det510 The wiper switch isn't plugged in. I can pull the switch right out of that little hole (if this is what you meant by if it was plugged in). Doesn't feel like anything is grabbing hold. if the whole rode comes out of the switch you prob need a new switch, by plugged in i meant the wiring at the back of the switch there is a connecter is it plugged in Quote Link to comment
AuosGnaf Posted May 2, 2010 Author Report Share Posted May 2, 2010 Thanks, SSR! It was a faulty switch. Plugged in a good one and now it's working. Quote Link to comment
sssr20det510 Posted May 2, 2010 Report Share Posted May 2, 2010 Thanks, SSR! It was a faulty switch. Plugged in a good one and now it's working. Glad you got it figured out Quote Link to comment
