datsundan Posted April 26, 2010 Report Share Posted April 26, 2010 I can't find a pic of a z31 3oozx rear sway. I once read somewhere online that you can use a z31 300zx rear sway bar on the rear of a 510??? Quote Link to comment
RadioLobo Posted April 27, 2010 Report Share Posted April 27, 2010 Like a stock one? I would also like to know :P Quote Link to comment
BJW's FiveTen's Posted April 27, 2010 Report Share Posted April 27, 2010 Here is a mock up I did on my 510 with a Z31 Rear Bar. I never installed this bar but It looked easy. I ended up with an adjustable rear bar so this one is still on the bench. Hope these photos help. I paid less than $10 for the bar with the brackets at my local pull a part I was just going to use some angle iron welded to the control arm to mount the end link. Good luck Bryce Quote Link to comment
bonvo Posted April 30, 2010 Report Share Posted April 30, 2010 after seeing this i think i need to find a z31 rear swaybar only thing i can see being an issue is it might limit downward travel Quote Link to comment
