Benkrwn Posted April 18, 2010 Report Share Posted April 18, 2010 Does anyone know where I can find a Carrier Bearing for my 1972 620??? Quote Link to comment
MicroMachinery Posted April 18, 2010 Report Share Posted April 18, 2010 Is the bearing itself bad? or just the insulator that surrounds it. I've had the insulator rot out, and I was able to make up a new one using thick rubber. Quote Link to comment
datzenmike Posted April 18, 2010 Report Share Posted April 18, 2010 X2 on that! Never seen a bad bearing. The rubber is now considered unobtanium. I made a rubber strip about an inch wide out of a piece of conveyor belt and wound around the bearing and slipped into place and clamped down with the help of the hanger bearing support. I think I left the black metal ring shown in the pictures off. Make it snug and clamp it down. I only did this as a temporary measure but it worked so well two years later it was still there. . 1 Quote Link to comment
MicroMachinery Posted April 18, 2010 Report Share Posted April 18, 2010 What I did was took the rubber strip and wrapped it around the bearing like Mike said. However, what I did next was I took the black ring and drilled small holes at the 12, 3, 6, and 9 o'clock positions. After I slipped the ring back over the rubber, I secured it with the screws through the 12,3,6, and 9 o'clock holes that I had drilled prior. Still going great. It's nice to know you have options.. INEXPENSIVE options, at that ;) 1 Quote Link to comment
datzenmike Posted April 18, 2010 Report Share Posted April 18, 2010 That there is ratsun! Quote Link to comment
kdennis Posted April 19, 2010 Report Share Posted April 19, 2010 Find a driveline shop that is a powertrain distributor and order a 1280-10 1973-1979 datsun 620. Picture shows bearing and rubber. http://www.powertrainindustries.com/catalogs_type.htm?type=Center+Supports Kevin Quote Link to comment
sick620 Posted April 19, 2010 Report Share Posted April 19, 2010 i just bought mine at schucks. :lol: Quote Link to comment
74datsun620 Posted May 16, 2010 Report Share Posted May 16, 2010 X2 on that! Never seen a bad bearing. The rubber is now considered unobtanium. I made a rubber strip about an inch wide out of a piece of conveyor belt and wound around the bearing and slipped into place and clamped down with the help of the hanger bearing support. I think I left the black metal ring shown in the pictures off. Make it snug and clamp it down. I only did this as a temporary measure but it worked so well two years later it was still there. . I love this fix!!!! Quote Link to comment
datzenmike Posted May 16, 2010 Report Share Posted May 16, 2010 Just so there's no confusion my pictures are of a good unobtanium rubber isolator and not the fix. Quote Link to comment
Tweeker521 Posted September 26, 2012 Report Share Posted September 26, 2012 Any one know we're I can get a housing for the carrier bearing on a 521 Quote Link to comment
arizonajones Posted November 11, 2013 Report Share Posted November 11, 2013 I made a rubber strip about an inch wide out of a piece of conveyor belt and wound around the bearing and slipped into place and clamped down with the help of the hanger bearing support. I think I left the black metal ring shown in the pictures off. Make it snug and clamp it down. I only did this as a temporary measure but it worked so well two years later it was still there.. I just used this same fix on my 720. The rubber fixed the clunk of the loose axle, but now the truck bed vibrates like crazy at about 30-35mph. Do you think that's the bearing (maybe a bad spot with some pitting?) or is it more likely that I need to move bolt positions on the axle? Quote Link to comment
