tonalteco Posted April 14, 2010 Report Share Posted April 14, 2010 I have a 1967 truck and wish to know if some one could give me ideas about how to modify or install a gastank which no longer has the original bracket on it. i swapped the bed and lost the brackets for the gas tank. mormally is supprted to the bed but wonder if i can use the set up from a different truck or different year. Also, would the main fillin hose work is i buy or get it from a earlier truck? Last thing....Does some one know where to buy the gas line that goes from the tank to the carby? Is it something pretty standard or has to be specialize line? thanks so much and pardon my ignorance tonalteco Quote Link to comment
DanielC Posted April 15, 2010 Report Share Posted April 15, 2010 I believe on a 1967 truck (520) the body parts are all measured in inches, they are not metric. Brake lines on my 1947 Willys jeep use the same flare nuts as my 1971 PL 521. I replaced the fuel hose just with 1/4 inch new rubber hose. the gas fill you will have to look a little more to find, but there is probably something domestic that you could adapt. Quote Link to comment
tonalteco Posted May 20, 2010 Author Report Share Posted May 20, 2010 Got it, I thank you much for taking the time to reply. since im converting to disc brakes i might go metric on all the brake lines all the way. as for the fuel line i will follow your advise i hope to find something that works. tonalteco Quote Link to comment
Charlie69 Posted May 24, 2010 Report Share Posted May 24, 2010 I will check on Saturday for a set of 520 tank brackets if you are interested. PM me if you are interestested. Quote Link to comment
