darrel Posted April 9, 2010 Report Share Posted April 9, 2010 Are the pedal boxes, clutch hard lines, clutch master all the same through out the run of the 620? I have a '78 with an auto and want to start collecting the parts to do the swap to manual tranny. Quote Link to comment
datzenmike Posted April 9, 2010 Report Share Posted April 9, 2010 Are the pedal boxes, clutch hard lines, clutch master all the same through out the run of the 620? I have a '78 with an auto and want to start collecting the parts to do the swap to manual tranny. Pedal boxes, master and push rod appear to be the same as is the slave and hard lines and hose. Quote Link to comment
darrel Posted April 11, 2010 Author Report Share Posted April 11, 2010 Thanks Mike. Maybe I should take a pic to compare with others to make sure. The 240z through the 280z they have been different. Same body style but sutble differences underneath. Quote Link to comment
Jersey Posted April 14, 2010 Report Share Posted April 14, 2010 when I converted mine from auto to 5spd, I just added the line for the clutch and it was kind of a bitch(time consuming)to install. After I got it done, I figured out that it would have been easier and faster to replace all the lines as one unit. Quote Link to comment
