datsundan Posted April 6, 2010 Report Share Posted April 6, 2010 Where can I find some solid crossember and mustache bar mounts for my dime? Quote Link to comment
JDM510 Posted April 6, 2010 Report Share Posted April 6, 2010 i could of swore i saw them here but now i dont see them idk... http://www.maddat.com.au/suspension-parts.php Quote Link to comment
Duke Posted April 6, 2010 Report Share Posted April 6, 2010 http://designproductsracing.com/510_RearSuspension.html Or you could do this also (taken from byron510 on the510realm.com) Most of this is just resource stuff. I've spent a lot of time reading over the years, then applying as much of it as I can to our old beloved machines. What can I say - I'm sick... and lovin' it.Mike, concerning the rear X member bushes - if you are looking for a solid rear end from a performance point of view - I've done the following mod on most of my sedans: (if you are replacing a stock worn out bush and are after a nice quiet ride, disregard the following) Remove (and drop to just below the mounting studs) the X-member onto a jack, pull off the large thin washer and rubber isolator (probably stuck to the body). Now replace the X member against the chassis using no washer or rubber. Concerning the two washers that were on the bottom side of the X-member mount, using the thick washer (call it washer A) that used to be under the lower formed "washer" (call this washer B). Place washer A onto the stud, invert washer B, place on stud so that the outside of the "cup now contacts the X member, (washer A is just taking up the space inside the cup against the steel inner bush), place a standard flat washer on next, and with a little Never-Seize on both the thread and the face between the nut and washer - crank it up tight until the center of the cup washer is hard up against the inner steel bushing. Your X member is now firmly in place, and this will eliminate some of the "rear steer" tendencies that are built into the car. I’ve always used a new nyloc nut – best source is your local Honda motorcycle shop as they have them in stock in the right fine thread pitch. This mod will be most notable when braking hard into a corner while slightly turning in - it helps under duress for you track type guys! Quote Link to comment
510six Posted April 6, 2010 Report Share Posted April 6, 2010 Check these links out http://designproductsracing.com/Z_Suspension1.html http://www.angelfire.com/extreme/280zxt/page17.html http://designproductsracing.com/510_RearSuspension.html Quote Link to comment
JDM510 Posted April 6, 2010 Report Share Posted April 6, 2010 the ones i was talking to you about at the show are these ones.. http://designproduct...uspension1.html but after reading that mod duke posted think ill just go with that!!! Quote Link to comment
