minitrucker4life Posted March 31, 2010 Report Share Posted March 31, 2010 what year datsun/nissan can i use the disc breaks off of? I'm working on a 74 620 bullet side Quote Link to comment
nismo dr Posted March 31, 2010 Report Share Posted March 31, 2010 search button up there is your friend. also this **DATSUN FAQ** Frequently Asked Questions - Look here FIRST! http://community.ratsun.net/topic/2105-datsun-faq-frequently-asked-questions-look-here-first/ and there is a brake (not break) section Quote Link to comment
Bleach Posted March 31, 2010 Report Share Posted March 31, 2010 521 front kingpin suspension is basically the same as the 620 http://community.ratsun.net/topic/16105-disk-brake-conversion-521/ This is how: buy custom parts. Either a bracket for the existing kingpin or a custom upper A-arm, then a whole Nissan truck spindle, hub, brakes, and a 1978-79 lower stock A-arm. http://community.ratsun.net/topic/146-disc-brakes-on-a-kingpin-truck/ Also, I'm moving this from Suspension to the Brakes section. Quote Link to comment
nismo dr Posted March 31, 2010 Report Share Posted March 31, 2010 Give a man a fish..... Quote Link to comment
Bleach Posted March 31, 2010 Report Share Posted March 31, 2010 i will also buy and install everything for you for free :D hehe Quote Link to comment
Pedro Posted March 31, 2010 Report Share Posted March 31, 2010 Here is some food for thought depending on how far you want to go. One of the NZ guys found that the hub and spindle of a particular nissan navara (you guys probably have an equivalent) bolt on to the 521 front arms. This then gives a disc brake and 4 pot nissan upgrade. A friend of a friend then told me that hilux 5 stud hubs will bolt straight on with minor modification and that nissan 4 pot callipers also bolt directly onto the narvara hubs, so i tried it and it works. Here is some photos for your viewing pleasure. Quote Link to comment
yello620 Posted April 1, 2010 Report Share Posted April 1, 2010 Thats just a D21 spindle with a 1990 Z32 caliper. Yes, the caliper will bolt to the spindle, but the rotor is not centered inbetween the pads properly and the rotor is over an inch too small. The pads hang over the edges of the rotor by about a half inch. I have already tried this method, didnt work. Quote Link to comment
Bleach Posted April 1, 2010 Report Share Posted April 1, 2010 Pedro, the 521 did not have ball joints in the States. Is your truck a 521 or is it a late 1970's 620? Quote Link to comment
Pedro Posted April 1, 2010 Report Share Posted April 1, 2010 Thats just a D21 spindle with a 1990 Z32 caliper. Yes, the caliper will bolt to the spindle, but the rotor is not centered inbetween the pads properly and the rotor is over an inch too small. The pads hang over the edges of the rotor by about a half inch. I have already tried this method, didnt work. You just get a rotor to suit with the right hat height, rotor height and width. I believe the truck is a 521 Quote Link to comment
minitrucker4life Posted April 2, 2010 Author Report Share Posted April 2, 2010 I'm working on 1974 620 bullet side. some guy told me that the 720 and the hardbody will interchange I'll have to get the whole front end.I don't know if it will work or not. Quote Link to comment
Bleach Posted April 2, 2010 Report Share Posted April 2, 2010 I'm working on 1974 620 bullet side. some guy told me that the 720 and the hardbody will interchange I'll have to get the whole front end.I don't know if it will work or not. 1983-85 720 had larger brakes which Nissan continued to use on the Hardbody trucks from 1986+ 1980-82 720 brakes were smaller, and very similar to the small disc brakes on the 1978-79 620 The 1978-79 front suspension is very different than the prior years of 620 trucks. There is not bolt-on easy way to get discs using all factory original pieces. http://community.ratsun.net/topic/20432-disc-brake-installed-on-a-drum-brake-truck/ You could find a 1978-79 standard cab short bed truck... then just use the frame with suspension and brakes. Put your cab, bed, and engine on it. Quote Link to comment
