CorAce Posted March 26, 2010 Report Share Posted March 26, 2010 This may be an odd request but I’m looking for head light retaining rings for 510 with a popped spot weld. I’m playing around with a set of lights that are just a hair to big, and didn’t want to wreck a good set. I also need a good set for my stock lamps as well. Just as an add on I’m looking for a set of up graded sway bars, LSD, Z wheel center caps, adjustable rear cross member and good tail light trim. Thanks Link to comment
GrizNutz Posted March 26, 2010 Report Share Posted March 26, 2010 hey man what size sway bars are you looking for? i have a set, front and rear, but ill have to check the sizes on them. Link to comment
CorAce Posted March 26, 2010 Author Report Share Posted March 26, 2010 Ya know I’m not sure, I think the most common up grade is 1” front and ¾” rear. Link to comment
Mesh-71 Posted March 26, 2010 Report Share Posted March 26, 2010 Hey, I think that I might have one or two popped headlight rings, I will see if I can round them up for you Link to comment
CorAce Posted March 26, 2010 Author Report Share Posted March 26, 2010 that would be sweet, we could call it a trade. :P Link to comment
GrizNutz Posted March 26, 2010 Report Share Posted March 26, 2010 ill measure them in the morning, gotta pull them out of the attic.. :D Link to comment
CorAce Posted March 26, 2010 Author Report Share Posted March 26, 2010 ill measure them in the morning, gotta pull them out of the attic.. :D Cool... let me know :) Link to comment
GrizNutz Posted March 26, 2010 Report Share Posted March 26, 2010 hey man I measured the sway bars this morning. Front AND Rear are both 3/4. I thought I had an extra 1" front bar but I cant seem to find it at the moment. Ill let you know if I do. The Rear has endlinks and Im sure that I have a couple extra set of bushings. Let me know if you want either of them. Link to comment
Sinnful Posted March 26, 2010 Report Share Posted March 26, 2010 I have some poped rings also. And I have a adjustable rear crossmember too. I'm located in battle ground Link to comment
CorAce Posted March 26, 2010 Author Report Share Posted March 26, 2010 hey man I measured the sway bars this morning. Front AND Rear are both 3/4. I thought I had an extra 1" front bar but I cant seem to find it at the moment. Ill let you know if I do. The Rear has endlinks and Im sure that I have a couple extra set of bushings. Let me know if you want either of them. I have some poped rings also. And I have a adjustable rear crossmember too. I'm located in battle ground PM sent to both :) Link to comment
philcas1987 Posted March 27, 2010 Report Share Posted March 27, 2010 Hey I got a front sway 1" sway bar. $60 bucks and its yours. I can get it to you today. Link to comment
CorAce Posted March 29, 2010 Author Report Share Posted March 29, 2010 Bump... still need head light rings. broken ones to play with and a good set for back up if my idea wont work. Thanks Link to comment
hang_510 Posted March 29, 2010 Report Share Posted March 29, 2010 ... still need head light rings. broken ones to play with ... how many do you need? i have a couple, another that 'popped' on the ring section. also have some other style(still datsun) that dont work perfect for a 510 Link to comment
CorAce Posted March 29, 2010 Author Report Share Posted March 29, 2010 I have two good ones now, so two more for my stock set up. I need at least three more popped ones to experiment on, but I'll take more to play with if you got them. whats the deal with this "other style"? Link to comment
