Wolf_78 Posted March 21, 2010 Report Share Posted March 21, 2010 I see this guy drive a 280Zx silver on south on 68th around 3:45 or so! Yeah I owned a silver 1983 280Zx identical like his but is not running I need help. I bought my Z back in 2002 from my old boss and it wasn't running so I got a mechanic to work on it and it was back on the road but the turbo was tosted. Well I enroll into college in the fall of 2002 and money became an issue so I wasn't able to buy tabs. I was parked till 2006 since then it feel like it wants to start but it won't at all. I change the fuel relay, fuel pump, change the starter, and did a complete tune up but it won't run. I will post some additional information about my car issues and photos soon after I'm done with finals. Hey Bleach your Z looks awesome by the way I notice your hood its stock or its aftermarket? Quote Link to comment
Skib Posted March 21, 2010 Report Share Posted March 21, 2010 moved to "Z Cars" youl get your tech help here. Quote Link to comment
Wolf_78 Posted March 21, 2010 Author Report Share Posted March 21, 2010 moved to "Z Cars" youl get your tech help here. Sorry I realize the mistake I made. How do I delete this post? Quote Link to comment
Skib Posted March 22, 2010 Report Share Posted March 22, 2010 Sorry I realize the mistake I made. How do I delete this post? no need, I moved it to the Z cars section for you Quote Link to comment
Bleach Posted April 1, 2010 Report Share Posted April 1, 2010 sorry for the delayed response. Post here again the next time you check the forum. Quote Link to comment
Wolf_78 Posted April 20, 2010 Author Report Share Posted April 20, 2010 sorry for the delayed response. Post here again the next time you check the forum. Thanks, so I want to apologized for such a delayed. Here are the photos of my baby that I promised! Hey Bleach, how much money did you invested on your Z? I love the way your Z looks like and I hope you can guide me to rebuilt mine. My Z has some tiny rust no bigge I can fixed them. I wanna repaint it but where can I get those turbo logos that goes below the door near to side skirts? Quote Link to comment
Bleach Posted April 20, 2010 Report Share Posted April 20, 2010 My car's paint job was decent when I bought it so it is not recent paint. It does look like at one time the original silver was repainted but they masked off right above the door decals so the decal and the paint behind it is original. You can buy aftermarket remakes of the turbo sticker that looks similar. [ur]http://forums.hybridz.org/index.php?/topic/89964-my-new-side-turbo-decalswhat-you-guys-think/[/url] If the sticker itself is ok and you're going with silver again you could just mask the lower rocker. I put about $2600 into the car after I bought it. Its hard to believe since overall it doesn't look a whole lot different. I got shocks, springs, ball joints, adjustable tension rods, new wheels, tires, 350Z seats, large sway bars, mustang shifter and knob, steering wheel, BOV, the front nose piece, and a spoiler that is not installed. It still needs some interior work and a sound system. Right now it has an aftermarket tape deck from the 90's. :) Quote Link to comment
nismo dr Posted April 20, 2010 Report Share Posted April 20, 2010 Rockin - pun intended - the Ratsun parking brake! Quote Link to comment
Wolf_78 Posted May 1, 2010 Author Report Share Posted May 1, 2010 My car's paint job was decent when I bought it so it is not recent paint. It does look like at one time the original silver was repainted but they masked off right above the door decals so the decal and the paint behind it is original. You can buy aftermarket remakes of the turbo sticker that looks similar. [ur]http://forums.hybrid...you-guys-think/[/url] If the sticker itself is ok and you're going with silver again you could just mask the lower rocker. I put about $2600 into the car after I bought it. Its hard to believe since overall it doesn't look a whole lot different. I got shocks, springs, ball joints, adjustable tension rods, new wheels, tires, 350Z seats, large sway bars, mustang shifter and knob, steering wheel, BOV, the front nose piece, and a spoiler that is not installed. It still needs some interior work and a sound system. Right now it has an aftermarket tape deck from the 90's. It will be repainted with the stock color. So I bought a new coil and now I get a strong spark but it seems I'm not getting fuel. I did bought a new fuel pump and a new fuel relay and install them about two years ago. Today I will remove the fuel injectors and inspect them maybe they are clogged. Any advices on how to do a fuel pressure? Quote Link to comment
jesusno2 Posted May 1, 2010 Report Share Posted May 1, 2010 did ya put fresh gas in the car? Quote Link to comment
Bleach Posted May 1, 2010 Report Share Posted May 1, 2010 You would need a fuel pressure gauge and run it inline of the fuel pressure side. I usually see the spark plugs go bad from setting more often. Take all six out and gently clean the tips. Then try using a little starting fluid in the intake. See if you get it to fire up a little. Quote Link to comment
Wolf_78 Posted May 4, 2010 Author Report Share Posted May 4, 2010 did ya put fresh gas in the car? Thanks it did not occured to me but I will put fresh gasoline. Quote Link to comment
Wolf_78 Posted May 4, 2010 Author Report Share Posted May 4, 2010 You would need a fuel pressure gauge and run it inline of the fuel pressure side. I usually see the spark plugs go bad from setting more often. Take all six out and gently clean the tips. Then try using a little starting fluid in the intake. See if you get it to fire up a little. I will do all that thanks, Bleach! Quote Link to comment
