JDMonster Posted March 20, 2010 Report Share Posted March 20, 2010 Im considering oredring the Techno Toy Tuning front and rear coilover conversion kit but I want to know how low im going to be able to go? Quote Link to comment
JDM510 Posted March 20, 2010 Report Share Posted March 20, 2010 buy his stuff and you can go lower then my car i only have 280zx struts NON stortend i need to get the shortend ones to acheive a better ride!!!! Quote Link to comment
thisismatt Posted March 20, 2010 Report Share Posted March 20, 2010 Depends on your wheel and tire size, and on your suspension geometry and modification. Rear camber and toe becomes a big problem the lower you go and the rear suspension has no adjustment in stock form. Even if you make modifications to allow adjustment you'll still be left with rather poor suspension geometry the lower you go without heavy modification to the rear floor pan/crossmember position. Quote Link to comment
