How low can I go on these?
JDMonster
  • Replies 2
Depends on your wheel and tire size, and on your suspension geometry and modification. Rear camber and toe becomes a big problem the lower you go and the rear suspension has no adjustment in stock form. Even if you make modifications to allow adjustment you'll still be left with rather poor suspension geometry the lower you go without heavy modification to the rear floor pan/crossmember position.
