520 locking fuel door WTB
  • Replies 6
Hi Mark,
I have a 521 fuel door, lock, & key that I could use the lock from.
On the 520 fuel door there is a raised area for opening the door that would need to be flattened out. Do you know how to shrink metal? I would need some help on flattening this out with out trashing the metal.
Thank you for any help you may be able to provide.
Kool. Why not use the 521 door as it is now ?
If you need to flatten out the raised part on the 520 door make a few cuts in it using a small cut off wheel, lay the door over a 2x4 & gently hammer it flat. Then simply tack weld the cuts back up :cool:
I know Daniel [slam] has a welder now maybe he can help.
  • 4 weeks later...
