mswit209 Posted March 12, 2010 Report Share Posted March 12, 2010 both my clutch and brake master cylinders are leaking so i want to replace them with a little flash i need to know the bore sizes because i am going to put in some wilwood brake and clutch master cylinders for a 72 4dr 510 Quote Link to comment
sssr20det510 Posted March 12, 2010 Report Share Posted March 12, 2010 Brake master depends on brake calipers used, stock is 7/8 zx is15/16 Quote Link to comment
mswit209 Posted March 12, 2010 Author Report Share Posted March 12, 2010 ok well i was planing on upgradeing the calipers so i should run a 15/16 anybody know the clutch master size i think its 5/8 Quote Link to comment
sssr20det510 Posted March 12, 2010 Report Share Posted March 12, 2010 I pretty sure it is Quote Link to comment
MicroMachinery Posted March 12, 2010 Report Share Posted March 12, 2010 It should say on the side of the master cylinder(s). Clean it off if you have to; the numbers should be in raised lettering on the casting. Quote Link to comment
hang_510 Posted March 12, 2010 Report Share Posted March 12, 2010 anybody know the clutch master size i think its 5/8 :unsure: checking... Quote Link to comment
racerx Posted March 12, 2010 Report Share Posted March 12, 2010 So we can use ZX, too? if so what year. Cuz it's getting harder to find stock brake master for 510s. Quote Link to comment
sssr20det510 Posted March 12, 2010 Report Share Posted March 12, 2010 So we can use ZX, too? if so what year. Cuz it's getting harder to find stock brake master for 510s. 80-83 zx will work, if you upgrade to zx struts and brakes you want to upgrade your master as well my clutch master is 5/8 Quote Link to comment
racerx Posted March 12, 2010 Report Share Posted March 12, 2010 80-83 zx will work, if you upgrade to zx struts and brakes you want to upgrade your master as well my clutch master is 5/8 So are you saying if you upgrade to ZX struts..What if I stick to stock set-up will a ZX brake master cylinder work? Thanks, racerX Quote Link to comment
sssr20det510 Posted March 12, 2010 Report Share Posted March 12, 2010 it should, but id upgrade anyways stock 510 brakes suck Quote Link to comment
