73-76 Turn Signal Switch Assembly
79D50
Hey People. This is a shout out to all Washington Residents. I am in dire need of a turn signal switch assembly in good working order for my 620. The plugs between the years 73 and 76 are all 6 pin square connectors and 77-79 are a 8 pin connector with an entirely different wiring harness.
If you have a 73-76 turn signal switch assembly please call 206.617.0649 or PM me. Thanks!
  • Replies 4
The turn signal arm assemblies were different from year to year and even different in the separate trim packages in each year. So be careful to get the same one to replace yours.
