jrock4224 Posted February 22, 2010 Report Share Posted February 22, 2010 anybody know what pin switch will work in that hole in the door jam.....i tried a standard one and the hole is way to big... wanna add courtesy lights when i open the door....and how big is the fuel tank in my 521, ggallons not dimensions...seems 9 gal fills it up every time... Quote Link to comment
denveratsun Posted February 22, 2010 Report Share Posted February 22, 2010 My 521 just had empty holes in the door jam...I found one at the JY that had rubber plugs in them..so I grabbed them and now thats what I got. :rolleyes: The factory light has a little switch in the bottom of it to activate it.I am not sure if there ever were actual switches there or not. 10.8 gallons for 1970-1971 Datsun 521 trucks. :cool: Quote Link to comment
family200 Posted February 23, 2010 Report Share Posted February 23, 2010 I added basic pin switches (alarm hood pins) to the upper part of the door jambs on my truck. I ran them to a relay to trigger under dash lights, and an alarm. Works great. Can take some photos tommorrow if you want. Quote Link to comment
jrock4224 Posted February 24, 2010 Author Report Share Posted February 24, 2010 actually thats t=what i tried bu the holes were to big in the factory location......i actually am trying to get some underdash lights up and running...i was gonna try to incorp the poverhead light too n the circuit since its right in the kick......i just kinda wanted to use the holes already there for my pin swiches but inless i mill something up i havent found a pin switch that works... pics would be great Quote Link to comment
dat521gatherer Posted March 6, 2010 Report Share Posted March 6, 2010 i think i have the only 2 521's with door jam switches. i used under hood light switches which are the same switch. most are worn but i found a few that are not so worn. 620 door jam switches work too. most datsun switches will work. clean the connector on the back of the switch and bend all the mounting prongs out before installing to insure a snug fit. Quote Link to comment
jrock4224 Posted March 16, 2010 Author Report Share Posted March 16, 2010 i think i have the only 2 521's with door jam switches. i used under hood light switches which are the same switch. most are worn but i found a few that are not so worn. 620 door jam switches work too. most datsun switches will work. clean the connector on the back of the switch and bend all the mounting prongs out before installing to insure a snug fit. are you talking about that swtich thats has the white nipple under the hood? any idea where to get some of those.....any pics of the switcheds in the truck ... either the pic of a 620 switch or the 521 hood switch... Quote Link to comment
dat521gatherer Posted March 18, 2010 Report Share Posted March 18, 2010 here is mine. the 620 door switches will work too. yes i always grab the ones under the hood when i see them at the junk yard. you can buy new ones for other datsun models on ebay an newdatsunparts.com but i think they are way to expensive. the hardest part is running the wire down the a pillar. i was going to take pics the last time i did it but i forgot. Quote Link to comment
nukeday Posted March 18, 2010 Report Share Posted March 18, 2010 I've never been a big fan of the spring loaded, 'open' style door switch. On my Rambler, I used two brake light switches and put those in instead. I used one jam nut on each side of the switch hole. They had to come in from behind, so it was a little bit of a pain, but the switches are enclosed and adjustable. I ran the ground to an eyelet and just screwed that to the kick panel sheet metal. Used the existing lead to the 'always hot'. If I remember right, I used a pair of those little stick on bumpers for cabinet doors on the doors themselves as the throw on the brake switch is shorter than the throw on the 'real' switch. My .02 cents, FWIW. :D Quote Link to comment
