A Couple of '81 210 Questions
A buddy of mine just purchased an '81 210 hatchback dlx the other day. The car has the A15 motor but needs the head gasket replaced.
I'm familiar with L motors but haven't had the chance to work on an A yet.
• Is it possible to replace the head gasket without removing the timing chain cover (the wooden block trick that people use for L motors) or am I going to have to pull the timing cover?
• Also, does any one know where to get lowering springs and blocks for this model car?
Thanks guys!
-C
  • Replies 10
Its a push rod engine so the cam is in the block. Super easy to do, just gotta make sure to do cold then hot valve adjustments after reassembly.
I used 510 rears(cut) and stock fronts(cut) then put rubber snubbers in the spring coils to stiffen it up. It will bottom out the shocks in front so take them in to a machine shop and have them cut off about 4in and rethread the shaft. You can also cut off the shock towers and raise them up. Would not recomend this cause all the measuring that you gotta do to make it right. I have a car that was done this way and it is pretty Hack. Drives weird and everything.
Yes, it's like 100 times easier than the L-series engine.
Just make sure
1. Get the block and head faces super clean
2. Get the threads clean and chased. Do not oil
3. Use a torque wrench, bolt in three stages in the Datsun pattern
Easy swap. You don't need to mill the head unless it's more than 4 thousands out of flat.
To lower one inch, just cut 1/4 coil front and rear, no blocks needed.
Thanks for the info., guys.
I was looking through the Haynes manual and it looks like the rocker shaft needs to be removed from the cylinder head, then the push rods slide out and then the head bolts get removed. Does that sound correct? And I don't need to worry about TDC right?
Thanks again!
-C
