BJW's FiveTen's Posted November 20, 2009 Report Share Posted November 20, 2009 Here is what I have, 78 810 strut Housings, GC Coilovers with 8" Spring#200. I Have T3 camber plates and roll center adjusters/spacers. Planing on cutting down the Strut.:) Want to know what insert will work with these parts. MR2 (Sw20?)? If so what part # Been told the VW insert is too short. I like tokico Products, Any one using AGX? am open to suggestions. I am looking for a nice low stance but some suspension travel as well. So what would you use???:confused: Thanks Bryce:eek: Quote Link to comment
BJW's FiveTen's Posted November 20, 2009 Author Report Share Posted November 20, 2009 I should have said it is for my Five Ten Quote Link to comment
DISLEXICDIME Posted November 20, 2009 Report Share Posted November 20, 2009 I thought the vw rabbit insert's where the same length as the sw20 mr2 inserts mine are 280zx strut tubes shortened 40mm with agx 4 ways off of a sw20 mr2 Quote Link to comment
BJW's FiveTen's Posted November 20, 2009 Author Report Share Posted November 20, 2009 Today 10:08 PM DISLEXICDIME I thought the vw rabbit insert's where the same length as the sw20 mr2 inserts mine are 280zx strut tubes shortened 40mm with agx 4 ways off of a sw20 mr2 So do you like the Agx struts? Quote Link to comment
Cuts metal like mad Posted November 20, 2009 Report Share Posted November 20, 2009 I just did I set of coilovers for a board member... the SW20 inserts fit the 280zx housings exactly... I think the AW11 insert might be the the better choice. Quote Link to comment
BJW's FiveTen's Posted November 21, 2009 Author Report Share Posted November 21, 2009 So who is running the Aw11, And Are they Koni, KyB, Tokico, please help, I just want to set it up right once:rolleyes: Quote Link to comment
