81datsun Posted November 18, 2009 Report Share Posted November 18, 2009 I want to put some fender flares on my 210. because my back wheels rub a bit. were can i find a set of flares that are either bolt on or metal? Quote Link to comment
Bleach Posted November 18, 2009 Report Share Posted November 18, 2009 bolt-on fiberglass flares can be found here. http://www.thezstore.com/page/TZS/PROD/50-1562 Quote Link to comment
81datsun Posted November 18, 2009 Author Report Share Posted November 18, 2009 thanks. is their anyway i could find some cheaper ones or are they all pretty spendy? Quote Link to comment
Bleach Posted November 18, 2009 Report Share Posted November 18, 2009 :) Not likely. I would consider $50 per fender pretty cheap for a brand new flare. If you can get a fender from a local wrecking yard for less than $50 each then look for a Dodge Omni or similar vehicle. They have large steel flares. Get two pairs of front fenders. 1 Quote Link to comment
81datsun Posted November 18, 2009 Author Report Share Posted November 18, 2009 okay thanks Quote Link to comment
b210in Posted November 18, 2009 Report Share Posted November 18, 2009 if you want some cheap flares, go to jcwhitney and you can buy a roll of fender flares to cover all four wheels. they are thick black flexable plastic, you just cut to the size you need and you are good to go. if you want to go cheaper than that, go to home depo and get a strip of roofing liner (i think this is what is called), cut some v shaped slits on one strip and also get some screws and bolt them on. this will give your car a cool southern ghetto look to it. Quote Link to comment
CharlieBucket Posted November 19, 2009 Report Share Posted November 19, 2009 i am going to flare my 77 B210 with toyota TE27 flares. they are the best fitting on a B210. they would probelly fit a 210 also. Quote Link to comment
OpelWagenGT Posted January 2, 2010 Report Share Posted January 2, 2010 bolt-on fiberglass flares can be found here. http://www.thezstore.com/page/TZS/PROD/50-1562 Anyone know if these would fit on a 72 1200 coupe? Quote Link to comment
