shifter
86720 ST
  • Replies 2
I want to put a shorter shifter in my 720, any suggestions. What will work as direct replacement
a shifter out of a Z car works great. Its quite a bit shorter and worked ok. But i had a L series trans yours may be different?
Z shifter on the bottom. it seems shorter then it looks. And it was nice and tight in the 720. felt like a short throw
I took one out of an early 80's 200sx. It is quite a bit shorter than your stock shifter. It has the same type attachment as the shifter that your 720 has. I used one on my 620 by simply turning the plastic pieces upside down. Tear yours out and you'll see what I mean.
