novita1021 Posted November 6, 2009 Report Share Posted November 6, 2009 okay guys i just picked up a full set of z32 calipers..so i know for the front i have to use vg s12 struts and z31 hubs and rotors but thats keeping it 4lug..what if i wanna do 5 lug and also put rear disc with z32 calipers and e-brake..i have an s14 sr in my car stock and realy have a hard time stopping so yeah haha..im also getting nistune and n62 maf with 550cc sards..so need stopin pawah!! any pointers how to aproach or get started..i just have the calipers right now.. Quote Link to comment
hoov100 Posted November 6, 2009 Report Share Posted November 6, 2009 okay guys i just picked up a full set of z32 calipers..so i know for the front i have to use vg s12 struts and z31 hubs and rotors but thats keeping it 4lug..what if i wanna do 5 lug and also put rear disc with z32 calipers and e-brake..i have an s14 sr in my car stock and realy have a hard time stopping so yeah haha..im also getting nistune and n62 maf with 550cc sards..so need stopin pawah!!any pointers how to aproach or get started..i just have the calipers right now.. find 5 lug z31 hubs, the z32 ebrake is drum style inside the rear rotor and the caliper is for stopping with the brake pedal only. So unless you wanna use z32 rear hubs, you arent going to be able to use the z32 ebrake cheaply/easily. Quote Link to comment
novita1021 Posted November 16, 2009 Author Report Share Posted November 16, 2009 thanks hoov100 for the reply.. well the rear hub and e-brake assembly i can get by today my buddie has a sload of spare z32 ebrake parts and rear stuff..so what would i need the rear hubs?which rotors do i use the z32 ones?and would i have to swap diff?or just the axels? thanks Quote Link to comment
sssr20det510 Posted November 16, 2009 Report Share Posted November 16, 2009 you can get the se s12 struts with 5 lug swap to z32 rotors and calipers i belive Quote Link to comment
novita1021 Posted November 17, 2009 Author Report Share Posted November 17, 2009 and what about the rears? i can find info on rears any ideas? Quote Link to comment
Cuts metal like mad Posted November 17, 2009 Report Share Posted November 17, 2009 Redrilled hubs, z31 rotors, custom caliper brackets, and IIRC... a certain year of 200sx used a single piston mechanical hand brake caliper. My memory doesn't store information very well, of things that I don't plan on using. :D Quote Link to comment
novita1021 Posted November 17, 2009 Author Report Share Posted November 17, 2009 ohh haha sounds hard for the rear..maybe its best to keep 4lug but 5lug will look hella baller..lol.. Quote Link to comment
sssr20det510 Posted December 2, 2009 Report Share Posted December 2, 2009 you can do what im doing and get the v6 s12 struts and 5 lug hubs, swap the hubs for z31 4 lug than when you have all the stuff for the rear swap the front back to 5 lug Quote Link to comment
five10freak Posted March 19, 2010 Report Share Posted March 19, 2010 i'm also working on this swap, as i have the Z32 brake setup sitting in a box. i am going a slightly different route only because i already have my suspension setup how i want it. i already have coilovers front and rear. front are techno toy tuning units made from the 280zx struts and GC coilover kit, rear are prolight coilover shocks from troy ermish racing and the 280zx disk brake swap done front and rear. soo far i have taken the 280zx hub and put it on my lathe and machined the circumference to fit the z32 rotor, re drilled the z32 rotors to 4 lug. with the hub back on the strut the rotor now fits perfect. fitting the caliper will take cutting off one of the stock mounting points on the strut, and moving it out 10MM, then weld it back in place( this is the step i am at now). keep in mind that i am using the 26MM version of the z32 front brakes, not the 30mm.with the 26mm z32 brakes the mounting points on the caliper are 100mm center to center, on the 280zx strut, the caliper mount is 90MM center to center i did a really quick check on the rear brakes and from what i can tell, using the 26MM z32 setup, the rotor fits on the rear hub perfect, keep in mind that i already have rear disk(280zx). the adapter bracket used for the 280zx rear caliper also fits the rear z32 caliper, i think the only thing to be done there is to increase the height of the bracket because the rotor is larger than the 280zx stuff. i should take some pics Quote Link to comment
Creepy Cruiser Posted March 19, 2010 Report Share Posted March 19, 2010 Yes please, lol. Quote Link to comment
