another 521 master cylinder upgrade
kezark31
you can you a willwood cylinder from you local speed shop, mounts up exactly the same. is a 3/4 bore the only thing i had to do was use an adjustable mount where is hooks to the pedal becasue the 521 was non-adjustable. i'll post pics later as well as the part number
  • Replies 5
