electric fan ?
bigjoe619
  • Replies 7
My fan is on the outside side of the radiator and points inwards towards the engine bay. It works very well. It's opposite of what's going on with the stock 510 setup (inside the engine bay, blowing out), but I think it makes more sense to work with the air flow naturally occuring when the car is in motion instead of against it.
What radiator do you have? You'll probably want a thermostatic switch to active the fan, since A) you don't always need it running, and B) you don't want to forget to turn it on if you're running a toggle switch.
The rabbit radiator has a thermostatic switch built into it; I'm running my fan through that switch.
The stock electric fans from stock cars blow into the motor. So if your fan is inside blowing out. I think that is big no no. Well as long as it does not overheat I guess... See natural air rushes in the car when your driving to cool the rad. but if the fan is pusHing that air out... there is no air passing threw the rad... Harder to cool?
At work we've had a few focus cars come in with complaints of overheating while driving at speed. The diagnosis is always someone replacing the cooling fans with an aftermarket assembly. The cheap aftermarket fans are wired incorrectly, actually blowing air from inside the engine compartment outwards through the radiator. So you end up with decent cooling at idle, when the fan can blow air through the radiator, albeit backwards, and no cooling at speed when the fan is trying to blow air through the radiator against natural airflow.
