athoose Posted October 23, 2009 Report Share Posted October 23, 2009 What does the throttle switch do on my 73 truck. I think its a throttle switch it is switched when the throttle is opened. Is it needed? I ask because I rebuilt my carb and the phenolic spacer broke so I had to remove it for now. Which created an alignment issue with the swich. I do plan to put it back on. ... the phenolic spacer. Thanks It is a hitachi carb if that matters. Quote Link to comment
athoose Posted October 23, 2009 Author Report Share Posted October 23, 2009 Coud it be a kickdown switch, for the auto? Quote Link to comment
athoose Posted October 23, 2009 Author Report Share Posted October 23, 2009 Ah, it is the throttle switch and is adjustable. Still, if I can't adjust it enough, can I remove it? Quote Link to comment
datzenmike Posted October 23, 2009 Report Share Posted October 23, 2009 The throttle switch plus a temp sensor switch in the cab, plus a forth gear switch in the tranny all are used to control the retard set of points. Depending on the air temp (warmed up), weather you are in high gear (yes?) and if you have the throttle open more than half way (yes?) will disconnect the retard set of points. At all other times the retard set are in operation. Don't worry about the carb switch, instead find the distributor relay and disconnect the plug to it. This will allow the dizzy to run on the advanced set of points permanently for best performance. Quote Link to comment
athoose Posted October 24, 2009 Author Report Share Posted October 24, 2009 Oh thats good to know. Thanks! Quote Link to comment
