OpelWagenGT Posted October 21, 2009 Report Share Posted October 21, 2009 So I am planning on buying weld on coilover sleeves from Ground Control and I want to know if anyone has done this mod to a stock 1200 strut without shortening it. I have read the thread about strut mods already but I want to know specifically if anyone has done this. Also I don't want to blow the shocks so I am wondering what stiffness of springs I should get I don't care if it rides rough also. http://www.ground-control-store.com/products/description.php/II=61 this is what I would be getting Quote Link to comment
ggzilla Posted October 25, 2009 Report Share Posted October 25, 2009 Yes lot of 1200 owners have bought the ground control. It works OK, adequate quality. You can leave it at stock height. You probably won't be able to find stock strength springs in the 2.25 in diameter size. Stock is 91 lb/in. The coilovers generally start at 175 lb/in Quote Link to comment
Pedro Posted October 25, 2009 Report Share Posted October 25, 2009 Are those sleeves metal or aluminum? Quote Link to comment
CypeSess73 Posted November 20, 2009 Report Share Posted November 20, 2009 yes. coilover sleeves are cheap and mainly for looks full coilover set ups include the shock portion and usually but not always dampner adjustable and height adjustable. these are what you want if youre all about getting that perfect set up. Quote Link to comment
2dat0z9 Posted November 20, 2009 Report Share Posted November 20, 2009 dats a good set up. any one knows if i can use it with the rabit shocks?? (cut and weld the struts, like with the 280z set up) will it work?? Quote Link to comment
