Str8_69 Posted October 12, 2009 Report Share Posted October 12, 2009 Any input appreciated. Approx 100K, clean carfax, but reviews on the web are fairly vague, anyone have some real experience with this genre? Truck looks awesome with almost all options.. Anything to beware of? V6 AT SC. Woulda posted in general but hoping the truck forum gets better results. Bounce me if not appropriate :D Quote Link to comment
nismo dr Posted October 12, 2009 Report Share Posted October 12, 2009 the SC isn't all that impressive - if you drive both you barely notice the difference(mostly just noise) timing belt is due at 105k -interference engine so needs to be done, check for exaust leaks - the manifolds like to crack; take it somewhere to pull codes, they like to hide knock sensor codes - doesn't turn the check engine light on but still indicates failure. edit: I work on them every day so if you have any specific questions feel free to pm me Quote Link to comment
Str8_69 Posted October 12, 2009 Author Report Share Posted October 12, 2009 the SC isn't all that impressive - if you drive both you barely notice the difference(mostly just noise) timing belt is due at 105k -interference engine so needs to be done, check for exaust leaks - the manifolds like to crack; take it somewhere to pull codes, they like to hide knock sensor codes - doesn't turn the check engine light on but still indicates failure. edit: I work on them every day so if you have any specific questions feel free to pm me Awesome info, thanks nismo. I did talk to a guy that said he had a cracked ex manifold on his but didn't know it was hereditary. Might rent a code reader to take if I go. :sneaky: Quote Link to comment
Bleach Posted October 12, 2009 Report Share Posted October 12, 2009 When I was looking into what Frontier to buy, the one you mentioned is a gas hog! Heaviest, biggest engine, supercharged, AND auto? probably 15mpg average, right? Quote Link to comment
HRH Posted October 13, 2009 Report Share Posted October 13, 2009 Ah yes, Nissans big turd of supercharging. A 3.3 SC with 210 hp, when the very same year the 3.5 was available, naturally aspirated with 240 hp. I never understood that. Quote Link to comment
