SRSANDS Posted September 27, 2009 Report Share Posted September 27, 2009 After building 1/2 inch spacers from raw stock AL, picking up ARP extended studs and tuner lugs for all hubs. And removing my ground control perches up a inch and shaving the rear LCA's, I have accomplished getting my 7" and 8"16" plus 32 offset rims mounted with no rubbing. This to me is great because it give me a larger variety of rims in the future if I switch. The only problem now I have is the front sits to damn high. I have ground control spings up front but I need to swap them out for shorter ones. Does anyone here have a shorter set they would be interested in trading for mine (they are new). If not can anyone recommend a place to get shorter ones at the same spring rate I have? I cant recall what # I have now or the free length or diameter, do you know? 2.5 or 2.25. Let me know.....I need shorter ones or someother fix.........thanks 195/50/16 up front and 205/55/16 on the rear Quote Link to comment
Cuts metal like mad Posted September 27, 2009 Report Share Posted September 27, 2009 Theres a company down near the port of tacoma that manufactures springs, you can get any length or spring rate you want... I can't recall the name though. Sorry... Quote Link to comment
BJW's FiveTen's Posted September 27, 2009 Report Share Posted September 27, 2009 What are you using for your strut mount? Stock stuff or camber plates? If you changed the upper mount could you move the spring up to lower the car??? Just a thought. Quote Link to comment
SRSANDS Posted September 27, 2009 Author Report Share Posted September 27, 2009 Theres a company down near the port of tacoma that manufactures springs, you can get any length or spring rate you want... I can't recall the name though. Sorry... Thanks man....if you can recall the name let me know Quote Link to comment
pepesnax Posted December 16, 2009 Report Share Posted December 16, 2009 I think the shop is Benz Spring Quote Link to comment
SRSANDS Posted December 17, 2009 Author Report Share Posted December 17, 2009 Thanks guys, all problems solved....camber plates too maybe if santa brings me what I asked for. I exchanged my used GC springs for 7" ones......oh and dropped a VG and trans in that brought it down nice and even with the wheel arch :) Quote Link to comment
LeX Posted December 17, 2009 Report Share Posted December 17, 2009 haha nice i have 7" springs, going down to 5" springs :D shortest they make with the spring rate I want (250lb) Quote Link to comment
