JDM510 Posted September 25, 2009 Report Share Posted September 25, 2009 i have a 74 620 i just called they said it could take 2 diff carrier bearings??? how can i tell if i have the 12mm or the 22mm??? Quote Link to comment
DISLEXICDIME Posted September 25, 2009 Report Share Posted September 25, 2009 take it off and take it with you or just measure it Quote Link to comment
datzenmike Posted September 25, 2009 Report Share Posted September 25, 2009 If you mean the drive shaft carrier bearing there is only one for all the models and years of 620. The previous 521 and the later 720 use a different one. The Nissan number is # 37521 B5000 Quote Link to comment
JDM510 Posted September 26, 2009 Author Report Share Posted September 26, 2009 when the guy at vatozone said 90 bucks for the bearing i said no no no i dont want the whole drive shaft just the carrier bearing he was like wtf that is the price for the bearing dumb ass didnt even get it i said screw that and did the ratsun fix will see how long it last Quote Link to comment
datzenmike Posted September 26, 2009 Report Share Posted September 26, 2009 The bearing has little load on it. It just supports the drive shaft in place. The thing that always goes bad is the rubber doughnut around IT. I wrapped a long strip of rubber conveyor belt around it and mounted it. Quote Link to comment
