SubwayGUY4 Posted September 16, 2009 Report Share Posted September 16, 2009 I was wondering if there are any other cars I can pull this off of or something My pair is to long? Whenever I turn them on the linkage binds against the car and gets stuck I looked at it and noticed the arm and the rotational part are not in sync at all, thus it was to long and is probably not the correct linkage for some reason. So yeah any other ideas would be great! thanks Quote Link to comment
datzenmike Posted September 16, 2009 Report Share Posted September 16, 2009 Finish filling out your profile so we know what you are driving (510, 610 Z car etc.) a location helps too. Someone that has what you need is more likely to reply if nearby. Is the wiper arm traveling too far off the glass onto the body or the actual linkage is rubbing under the cowl? The arms are splined and come off. With the wiper set in the off (parked) position place the arms back on in the correct lowered position. Quote Link to comment
SubwayGUY4 Posted September 16, 2009 Author Report Share Posted September 16, 2009 oh ya forgot to mention its a 510 and yeah the linkage just rubs under the cowl. the arm can't even make half a rotation without it hitting something i'll try to take pics tonight Quote Link to comment
SubwayGUY4 Posted September 17, 2009 Author Report Share Posted September 17, 2009 The first 3 pictures are the actual linkage itself. After looking at this diagram from dimequarterly http://dimequarterly.tierranet.com/tech/wiper_rebuild.jpg I was beginning to think this isn't the same linkage thus the rubbing issues shown on picture 4 the red is what should be connected and the yellow circle is how far the red can rotate as you can see its short As always any feedback would be much appreciated its about to rain soon :blink: Quote Link to comment
philcas1987 Posted September 17, 2009 Report Share Posted September 17, 2009 I think you have the whole linkage backwards. The arm that hooks up to the motor comes from the passeger side. Quote Link to comment
datzenmike Posted September 17, 2009 Report Share Posted September 17, 2009 The long linkage between the two wiper pivots should have the bend in the V pointing down. Needs to be flipped 180. V down. Quote Link to comment
