xAH510x Posted September 13, 2009 Report Share Posted September 13, 2009 does anyone know about a stock/ factory alignment parts for the rear swing arms?other than the one that datsport has,its more than my budget allows.Is it even necessary? Quote Link to comment
71ka510 Posted September 13, 2009 Report Share Posted September 13, 2009 dimequarterly.net penultimate crossmember Quote Link to comment
oldschoolrice Posted September 13, 2009 Report Share Posted September 13, 2009 As far as I know, the options for rear suspension adjustment are slotting the stock rear control arm mounting points, and the adjustable brackets (like the ones sold by Datsport). There might be other options out there that I don't know about. I would say the necessity depends on your plans for the car. How slammed do you want the car? (Seeing as the main reason for needing the adjustments is when lowering the car excessive camber and toe are induced) Do you plan on tracking/racing the car? I have been driving on my stock rear crossmember with lots of camber and toe for about a year and a half now. It is possible to go without althought tires get eaten up pretty quickly and you don't have the optimal rear alignment. My personal opinion is thar the adjustment IS necessary, but that is because my car sits pretty low and I do plan on tracking and possibly racing my car. I am about to order the Datsport do-it-yourself kit myself, finally! I'm not sure what your budget is, but if you think you might need it, the do-it-yourself kit with crossmember bushings and control arm bushings can be had for less than $500usd from Datsport. All you would need is a friend with some decent welding abilities. Hopefully this was helpful. Quote Link to comment
Byron510 Posted September 14, 2009 Report Share Posted September 14, 2009 (edited) I don't want to push my wares, but I came up with a solution for DIY’ers a few years ago that have made many people happy with their set ups. I had used slotted X members for many years, but got tired of either the pivot points moving on me (or welding them in place so that you can't adjust it later on which is almost as bad). Slotted X-members are also a bit of a pain to set up accurately on an alignment machine where time is of the essence, and lastly you really don't get the toe adjustment needed for some applications. So my solution was to replace only the inner LCA bracket on the X-member. A few people here and on the 510Realm have used them, and are really quite happy with the set up. Here is the set up on the Bronze, since the photos are not working on the Realm at the moment; Here's the link to the parts on the Realm: http://www.the510realm.com/viewtopic.php?f=10&t=6946 It's just another option - hope it helps. Byron Edited September 14, 2009 by Byron510 Quote Link to comment
freaky510 Posted September 14, 2009 Report Share Posted September 14, 2009 Iam saving a few coin for these they are one of the best mods you can do for a dime suspension Quote Link to comment
hang_510 Posted September 16, 2009 Report Share Posted September 16, 2009 does anyone know about a stock/ factory alignment parts for the rear swing arms? no 'stock' adjustment possible. slot it or buy a set of Byrons brackets. i have a set(local) for sale from him. Quote Link to comment
inline4 Posted September 16, 2009 Report Share Posted September 16, 2009 no 'stock' adjustment possible. slot it or buy a set of Byrons brackets. i have a set(local) for sale from him. how much. Quote Link to comment
hang_510 Posted September 16, 2009 Report Share Posted September 16, 2009 (edited) how much. double for you! :lol: send byron a PM (i cant find the price...) ship $$ would be low Edited September 16, 2009 by hang_510 Quote Link to comment
Byron510 Posted September 17, 2009 Report Share Posted September 17, 2009 Cost is $320, I've never changed that price since I started the first run; http://www.the510realm.com/viewtopic.php?f=10&t=6946 UPS is usually 25-30 bucks. Quote Link to comment
xAH510x Posted September 27, 2009 Author Report Share Posted September 27, 2009 no 'stock' adjustment possible ill probably just have stock adjustment for now until we're done with the car and then upgrade to the racing adjustment kit. Quote Link to comment
