SpooF Posted September 9, 2009 Report Share Posted September 9, 2009 ok so i can't seem to find a Pinion for my L16 and i went to the deal they got me one but its to short and had to many teeth mine is 17 teeth and is about 3 1/2 long from top to bottom anyone know where i can get one? or if this pinion is from a different tranny? thanks Quote Link to comment
SpooF Posted September 9, 2009 Author Report Share Posted September 9, 2009 anyone?... Quote Link to comment
datzenmike Posted September 9, 2009 Report Share Posted September 9, 2009 (edited) The tranny is stock? Speedo on driver's side? Chances are good it's been swapped. Can you post a picture of it? The Black 17 tooth one on the left is, I think, from a F4W63 likely from a 510 or 521. The others are from a newer 5 speed. http://i138.photobucket.com/albums/q251/datzenmike/Tranny/00270018.jpg[/img]"] Edited September 9, 2009 by datzenmike Quote Link to comment
SpooF Posted September 10, 2009 Author Report Share Posted September 10, 2009 thanks for the picture. i have the black teeth but where can i order one? some guys sell them on ebay but his is to short. yeah the speedo pinion can from the driver side, so would that be stock? ill try to get pictures Quote Link to comment
datzenmike Posted September 10, 2009 Report Share Posted September 10, 2009 Likely stock as only the F4W63 that bolts to an L series has the speedo on the driver's side. I'll get you a pt. number later. They probably ordered the wrong one. Quote Link to comment
SpooF Posted September 10, 2009 Author Report Share Posted September 10, 2009 ok thanks Quote Link to comment
SpooF Posted September 14, 2009 Author Report Share Posted September 14, 2009 can someone get me the part number or where to get one? thanks Quote Link to comment
datzenmike Posted September 14, 2009 Report Share Posted September 14, 2009 You said yours is about 3 1/2" long so you must have one. I assume the plastic gear is broken? The plastic gear (pinion assy.) is on a long thin shaft held in place by a roll pin. Tap the roll pin out and the pinion assy will drop out. The speedo pinion assy.... (its just the plastic 17 tooth cog on a spindle) is part number: 32703 22001 about $10 at dealer. Quote Link to comment
SpooF Posted September 15, 2009 Author Report Share Posted September 15, 2009 yeah its just the pinion thanks for the part number i hope my dealer can order one because last time they order a 19 tooth Quote Link to comment
