Distributor and coil
As some of you know I gotta build another hood scoop for mine and well Im doing things now to get that engine under the hood better.So Im looking for an aftermarket distributor and coil for it to clean up the engine and make it look better.Lemme know if there is a Mallory or Crane set up...basically something other than factory.
  • Replies 9
What about going distributorless and running an EDIS system?
Search slodats first 510 build.
this would an and idea, you can get all the parts you need from a ford escort (i think i still have parts for edis also)and then an 80 dollar control unit and your done
