dat u racing Posted August 18, 2009 Report Posted August 18, 2009 cann't locate fuse? also no low beam, no power to sockets, only high beam on right side works ,power to center wire at socket Quote
dat u racing Posted August 19, 2009 Author Report Posted August 19, 2009 ok so i changed the turn signel switch and now everything seems to work except low besms? Quote
72240z Posted August 19, 2009 Report Posted August 19, 2009 High miles? Check the switch in the column? Quote
datzenmike Posted August 19, 2009 Report Posted August 19, 2009 I don't have diagrams for the D-21 but it likely has a relay like the 720. The headlights have power to both hi and low and the relay selects and applies ground to either hi or low beams to light them. Quote
72240z Posted August 19, 2009 Report Posted August 19, 2009 Ya I have the diagrams if needed. I mention the column switch because mine will go from low to high beams when I put my left blinker on. I read in forums it's common that the switch gets all worn and contacts cross. Just throwing it out there, relay sounds good too. Quote
