silverdragon84 Posted August 17, 2009 Report Share Posted August 17, 2009 I need some info on how hard it is to swap a 1973 620 cab and bed on to a 1984 720 4x4 frame. any help would be great. I noticed i would have to use the steering column out of the 720 because of the power steering. Oh I am keeping the z24 in it. The swap is not for looks for the most part it is so i can get the 4x4 the 720 cab is in bad shape my 620 is rusted out under it but i am fixing that before i drop it on the other frame and the mounts look to be the same for the cab. I am also doing a 3-4 in body lift when i swap. If you need more info just ask and i will let you know because i need all the help i can get. thx Quote Link to comment
datzenmike Posted August 17, 2009 Report Share Posted August 17, 2009 I have my '78 on an '82 frame with a 4" lift. Don't remember any probs. Quote Link to comment
Cuts metal like mad Posted August 18, 2009 Report Share Posted August 18, 2009 as long as you can weld, all should be good. Quote Link to comment
silverdragon84 Posted August 18, 2009 Author Report Share Posted August 18, 2009 thx just wondered how hard it would be i almost have the 720 striped down and i only got it last night all i have to do now it finish prep work on engine bay interior is striped and bed is off oh do you think a 3-4 in lift will clear 32x11.50r 15 tires on steal chevy american race rimes they are rubbing the finders now when i turn it some and there is no lift that is what the truck had on it when i got it oh i can weld i have access to several types of cutters and welders and plenty of metal i will post picks when i am done with it in to much of a hurry to do a wright up on it Quote Link to comment
datzenmike Posted August 18, 2009 Report Share Posted August 18, 2009 I have 33 X 12.5s but the suspension is modified. 4" on stock suspension with 31 X 10.5s rubbed so I hammered the floor in for clearance. You can turn the torsion bars up for a bit more room, but... Quote Link to comment
silverdragon84 Posted August 18, 2009 Author Report Share Posted August 18, 2009 (edited) yea lifting by the torsion bars changes the camber angle the front and can affect the tow angle as well i will lift alittle with the torsion bars but not a lot will probably just bang floor in some and mod the fenders Edited August 18, 2009 by silverdragon84 Quote Link to comment
silverdragon84 Posted August 18, 2009 Author Report Share Posted August 18, 2009 quick ? will a down draft carb off of a dastsun L20 fit on a Z24 intake ??? Quote Link to comment
